Results 1 to 20 of 21
Thread: My junk coming together
    Finically found some motivation with the weather getting nicer. Engine side of things together with new cam and new intake set up. New fuel system from pump to rail, a few other little things. A pile of details left but the list is getting shorter
    South Hills, PA
    4,052
    Wow!!!
    It's all about the Benjamin's!
    Sent from my SM-G935V using Tapatalk
    looks like that intake should flow some good air
    I'm going to start the season with the 5858 turbo but an upgrade is coming. Moving from Precision to Borg Warner, SXE300 type stuff ;)
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    So far I love my BW s369-sxe on the Mach. I think you'll like that series.
    Fairmont, WV
    2,467
    S363SX-E ? https://agpturbo.com/borg-warner-s36...8-13009097006/
    Seems like 78 lb/min would be good for at least 150hp over your current turbo. The compressor map looks great for the strip, especially if you can really rev it.
    The goal is to be able to rev it more ... the 5858 was a great fit with what my combo flowed and where it stopped making power (intake and cam driven). Now with then new cam and intake, the turbine is a choke. Rough rough numbers, at 6,000 rom and 30# boost the turbine pressure is 1.5:1 boost pressure ... new turbo will be very close to 1:1 at 7,000 rpm ... the risk is how it will come off launch boost. That's why I'm going with the forge milled wheel hoping it helps a couple hundred RPm. I have a pretty good hook up on the BW stuff now so am getting a solid deal on this.
    Fairmont, WV
    2,467
    7K shift will help a lot. I agree it might be lazy off the line. 6K rpm 2-step. :)
    I'm 6400 now, likely 6800 after this
    Fairmont, WV
    2,467
    This is why we get along.
    more rpm fixes everything
    Ran out to test and tune last night for a bit and picked up some C12 for start up. The Vert makes a good parts hauler
    Broke both of my transmissions down for inspection. Had the input pilots ground to 4 banger pilot diameter so I can go back to a bearing instead of a bushing. Bushing worked but just could not predict when it would fail until it ate a gear (I knew it then). Put them back together tonight, ready to install one of the tomorrow.
    why are the teeth angled on the one ????
    Believe it or not, the 2.92 helical has become my preferred weapon of choice. For the life of my I cant figure out why, but it is sooooo much smoother than the straight cut box on gear changes. Two different animals for sure, the helical is about finesse, the straight cut is rape your cousin brutal.
    Fired the junk up tonight ....
    https://youtu.be/4DOzo9OBln8
    joe THE BIG KOALA's Avatar
    Feb 2009
    Vandergrift
    1,117
    It's alive. Is it much louder than it was can't tell by video.
    2019 Hellcat
    Louder and deeper
    South Hills, PA
    4,052
    Louder and deeper
    Dak said that once
