Originally Posted by
RUSH2112
Hey Jared - I told you that you could share my thread......
Anyway here are my thoughts
Check for loose or unhooked grounds in the engine compartment. there are two ground wires on the radiator support behind the headlights. Also sounds like your headlight switch is shorting out. However the "driving" fog lights are not supposed to work unless the head lights are on. If they come on at any other time,then they have been re-wired. This is standard on any GT fox .Hope this helps
