Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: '01 GT short-term powa R E S U L T S
  1. #21
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Quote Originally Posted by Troll View Post
    Cam, is this still so with a custom tune? does the IAT sensor still pull timing or does the tune override it?
    Ray already answered this, but I agree that it would depend on the tuner. I would imagine that you could find some extra horsepower by not pulling timing, but I wonder how hot the ambiant temp would have to get before it would cause some detonation if the timing never retarded.. They actually sell resistors on e-bay that plug into the iat sensor to fool the computer that the air temp. is always cold so that it won't pull timing.
  2. #22
    Dec 2006
    Melcroft
    420
    Quote Originally Posted by Cam99 View Post
    I heard that buying one of those resistors is the worst thing you can do to your car.
    2008 Ford Fusion SEL V6
  3. #23
    Melcroft
    4,178
    Quote Originally Posted by Rob_GT1997 View Post
    I sure wouldn't put one on mine, but in theory it would work. The intake air sensor just has a resistance value that varies based on the temperature, the resistor just provides the sensor a constant value (which would keep timing at max advance)
  4. #24
    5,822
    2019 Colorado ZR2
  5. #25
    Given rule is 100hp = 1sec, 100lbs = 1 tenth(course when it comes to heavy vehicles or low ET vehicles then more power or weight reduction is needed to run faster).
    I'd say pulleys on a 2v mod motor are good for about 10-12hp at the flywheel which should drop about a tenth off the ET of a 99+ GT.
    As for the IAT sensor. On earlier cars that had seperate IAT from MAF you could pull sensor from intake tube and put it in fender where air should be cooler. I think I tried that on my 2000Gt but don't remember much if any improvement at track.
  6. #26
    5,822
    2019 Colorado ZR2
  7. #27
    5,822
    2019 Colorado ZR2
  8. #28
    Fuwkawee
    5,151
    Pulleys feel good. Now, is it because it's 60* outside today or did they really do something? One thing I do notice is that it's much smoother down-shifting. I guess it makes sense with less drag on teh crank... just seems to rev a lot smoother and decel with ease. I'm happy now... when's the next dyno day. Car prolly never make it to the track. Might as well be a DYNO QUEEN.
    Bring it to the track one time I want to race the old pig and put a whooping on it.
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
  9. #29
    5,822
    2019 Colorado ZR2
  10. #30
    Dec 2006
    Melcroft
    420
    being that its 60* today did have a factor my car was running awesome today too
  11. #31
    3,499
    Not sure if 100 lbs. weight reduction is *worth* a tenth.( Where the weight is takin' out of and *if* the car can hook after the weight reduction) What I've discovered is the requisite 100 lb. loss or less when the car becomes lighter, is that it will give you 1 MPH. To say a tenth per 100 lb. requires proper weight distribution and a suspension that is working.
  12. #32
    Robinson
    3,842
    next time... 350/350
    Hot $hit! That would look good in somthing old.
    87 GT
    93 Notch
    60 Country Sedan
    Fairlanes/Galaxies 59-68
    67 Contiental 4 door
    06 Powerstroke
  1. Doesn't look good for a long-term deal for Wallace
    By PaxtonShelby in forum The Bar
    Last Post: 08-01-2012, 11:31 PM
  2. GM Powa!!!
    By Wolfpack Speed in forum Wolfpack Speed
    Last Post: 07-11-2011, 04:53 AM
  3. 95 Short Block
    By Mark Aubele in forum Ford Vehicles
    Last Post: 04-02-2011, 08:53 PM
  4. Short throws.......
    By LXguy88 in forum S197
    Last Post: 05-22-2008, 11:12 AM
  5. '01 GT / short term powa goals !!!
    By Troll in forum S197
    Last Post: 02-12-2008, 09:58 PM
