Results 1 to 20 of 21
Thread: Bowling Green Picture
    Nice picture from NMRA Bowling Green.
    that may have been my last outing for 2017...
    had as a host of stupid issues, blew off a charge pipe,,blew the fuel pump fuse twice, they got us lost in the woods on the cruise and over heated the clutch. Ended up with the car smoking pretty bad on the second pass and pulled out. Good thing I did because it also broke a lower control arm bolt and the arm hit the floor of the trailer as I loaded up.
    Time to start building a new bullet. Shame is the one in there was built for 2013 season, barely has 500 passes on it and only 10,000 Street miles ... I’m easy enough on my stuff that’s almost a shame, lol
    And this was real close to a disaster ... luck it came out in the trailer and not on the track.
    now upgraded to 5/8” grade 8 bolts
    Dang...that's fortunate right there...
    joe THE BIG KOALA's Avatar
    Feb 2009
    Vandergrift
    1,117
    Nice to know you take it easy on your stuff.lol
    2019 Hellcat
    2015 Norwalk NMRA true street 13 second winner
    Were those still 1/2" bolts? I've bent enough of the 9/16" stuff in the past.
    yeah, got me thinking after I had some time to think about it.
    Quote Originally Posted by THE BIG KOALA View Post
    nothing but pampered easy going life for my stuff.
    yeah 1/2” bolts. It sheared right at the first thread. Now 5/8” on the front with a full heim joint. I routinely check all the suspension bolts and had a wrench on this bolt before I loaded up for BG. I think the bolt was jammed up in the joint on that arm. The bushing is trashed, so I replaced them
    Wow....just Wow.
    South Hills, PA
    4,052
    Thought u had rod solid bushings on her. Wowzers
    Those was maximum motorsports HD lowers. They are solid, the poly you can see is only on the outside to keep the arm from twisting. Is is a spherical bearing in there, with aluminum sleeves, then the bushing sits over the aluminum sleeve. I think the aluminum gauled to the bolt.
    Its really the same as a rod end arm
    South Hills, PA
    4,052
    I see no heim
    It’s a spherical bearing inside the housing with a poly insert to keep it from rotating
    The new arms are just a heim.
    the old arms are just like this except there is a tube around it. Trust me they are solid bushings in there
    South Hills, PA
    4,052
    Wonder if the arb added this year made it weaken the bolt. U leave hard. Want you to be safe.
    glad you got it all fixed
    Quote Originally Posted by TooFast98Cobra View Post
    thanks,I would think the ARB should HELP by making the load more equal. It doesn’t leave twisted up any more.
    On that topiv, it’s a little weird. If I had a back half ladder bar car the front heim joint would require a safety strap (loop around heim). With stock suspension cars we run the same heims but no requirement. I was looking You could but a loop under the torque box to catch the arm anyway. Eh, random thoughts, now 5/8”bolts and I’ll change them every season going forward.
    lol, it’s fixed suspension wise. Motor is hurting. I’m going to try one more time, mostly to see if suspension works. But don’t expect any big numbers out of it.
    U.S. Citizen 86GT's Avatar
    Sep 2011
    Monroeville
    323
    Did you figure out what’s wrong with your engine yet?
    Lil' Blackie, also a Rodeheaver hot rod
    Black Bess : n/a 347 T56 magnum,426 hp/ 427 tq
    Best time at Keystone 11.68, best speed 122.95 mph (right lane)
    Built, tuned & made possible by Tim Rodeheaver
    Rodeheaver's Hot Rod Shop
    15 W. Cross Ave.
    Masontown Pa. 15461
    724-737-5088
    www.RodeheaversHotRod.com
    Well motor is worn out but still runs. I’m thinking about giving it a try Saturday to at least try suspension. Regardless I’ve started the build of a new bullet. Got my core mostly stripped down a ready to go to the machine shop Saturday to be tanked and cleaned so I can fill it, then back for machining.
    Where's the other half of it?
    Sent from my SM-G935V using Tapatalk
    That's what she said!
    imagine if I had both halves.
    You don’t have any other options for aftermarket blocks do you Bob?
