Results 1 to 16 of 16
Thread: SCMC's Fastest ET's
    Feb 2015
    904
    SCMC's Fastest ET's
    Just thought it would be cool to get an idea of what the fastest cars on the board are. It's cold outside and I want to talk drag racing, so I thought it would be cool to get a list going of the cars on the board. Doesn't matter if you're slow like me or not. Best ET of the fastest car you currently own. If you beat your previously listed time, please update your old post, so this is manageable. Template at the bottom of this post. Eventually I will toss this in a formatted list of some sort.
    I guess I will go first because its my f'n idea.
    Date of Run: 10-30-2015
    User handle: JeffreyCole
    Real Name: Jeff Cole
    60' ET: 1.7177
    1/8 ET: 7.6110
    1/8 MPH: 95.48
    1/4 ET: 11.7754
    1/4 MPH: 119.87
    Vehicle (Year, Make, Model) 1990 Eagle Talon
    Engine size (Displacement): Stock 2.0
    Power Adder 1 (If applicable): Turbo - Forced Performance journal bearing "Black" @ 30PSI
    Power Adder 2 (If applicable): N/A
    Approx. Weight (with driver in LBS): 3100?
    Track: Keystone Raceway Park
    Drivetrain (AWD, FWD, RWD): AWD
    Trans: Auto (stock or built) or Manual (stock or built): Stock Manual
    Tires (Street, DR, Slick) & Size: Street 205/55/16
    Fuel (type(s), percent used): 93 Octane pump fuel
    Future goals: 10's on street tires and a pump fuel
    Date of Run:
    User handle:
    Real Name:
    60' ET:
    1/8 ET:
    1/8 MPH:
    1/4 ET:
    1/4 MPH:
    Track:
    Future goals:
    Best MPH: 132.21
    Best 60' 1.490
    Feb 2015
    904
    Reserved for future use.
    Best MPH: 132.21
    Best 60' 1.490
    charleroi
    478
    94 mustang vert
    Boss Block 331
    Masterpower 67 mm
    Ptc c4 with brake
    Keystone raceway park
    10.96 @ 135
    Switched drive line into a fox and went to an 88mm turbo hoping for 10.00 or 9.99 this coming year.
    Oct 2010
    Carmichaels
    219
    Old man in an old Ford
    9.85 @ Keystone
    Date of Run: 11-26-16
    User handle: Pure Stock
    Real Name: Joe
    60' ET: 1.407
    1/8 ET: 6.682
    1/8 MPH: 102.50
    1/4 ET: 10.491
    1/4 MPH: 128.68
    Vehicle (Year, Make, Model) 2011 Ford Mustang GT
    Engine size (Displacement): 5.0
    Approx. Weight (with driver in LBS): 3,150
    Track: Cecil County Dragway
    Drivetrain (AWD, FWD, RWD): RWD
    Trans: Auto (stock or built) or Manual (stock or built): Stock manual MT-82
    Tires (Street, DR, Slick) & Size: Slick, 28x10.5x15
    Fuel (type(s), percent used): FTW Purple +
    Future goals: Get this damn thing down the track on a clean pass!
    Date of Run: 2012
    User handle: Paxtonshelby
    Real Name: Ron
    60' ET:
    1/8 ET:
    1/8 MPH: 92
    1/4 ET: 12.14
    1/4 MPH: 114
    Vehicle (Year, Make, Model) 1966 Mustang Coupe
    Engine size (Displacement): roller cam 302 (1985 block)
    Power Adder 1 (If applicable): Paxton Novi 1200
    Approx. Weight (with driver in LBS): 3,300
    Track: Quaker City Raceway
    Trans: Auto (stock or built) or Manual (stock or built): Stock manual T-5
    Tires (Street, DR, Slick) & Size: Slick, MT ET Streets 235/60/15
    Fuel (type(s), percent used): pump 93
    Future goals: Get car road course ready and drag strip ready with the new motor, brakes, steering, suspension, tires. No idea what she'll run - the 12.1 @ 114 was with a 2800rpm launch so I wouldn't break the original stock T-5.
    Jun 2007
    N. Huntingdon
    1,596
    1/4 ET: 11.07
    1/4 MPH: 125
    Vehicle: 2013 Mustang GT
    Engine size : 5.0 FBO
    Power Adder: Nitrous
    Trans: MT82
    Tires: 28" Hoosier's
    Fuel: E85
    Chris
    2016 Chevrolet Volt
    2010 Jetta TDi Cup Edition
    1964 Lincoln Continental
    If You Wanna thedak's Avatar
    Jul 2008
    DMB
    Date of Run: 2015
    User handle: thedak
    Real Name: Matt
    1/4 ET: 10.48
    1/4 MPH: 134
    Vehicle: 2013 Nissan GTR
    Engine size: 3.8L
    Power Adder: Factory Turbos
    Approx. Weight: 4000lbs
    Track: Keystone
    Drivetrain: AWD
    Trans: Factory OEM
    Tires: Dunlop All Seasons
    Fuel: E83
    Future goals: Your Mom
    Date of Run: 11/12/2016
    User handle: martin0660
    Real Name: Bob Myers
    60' ET: `1.352
    1/8 ET: 6.48
    1/8 MPH: 104.74
    1/4 ET: 10.20
    1/4 MPH: 133.95
    Vehicle (Year, Make, Model) 84 Mercury Capri RS Turbo
    Engine size (Displacement): 2.3 liters, 140 cubic inches
    Power Adder 2 (If applicable): Driver mod
    Approx. Weight (with driver in LBS): 2985 as raced
    Track: Mason Dixon
    Trans: Auto (stock or built) or Manual (stock or built): T5 (at that time, now G101a)
    Tires (Street, DR, Slick) & Size: 28-11.50-15 Quick Time Pro (DOT)
    Fuel (type(s), percent used): Pump 93 with torco to 100 octane mix
    Future goals: 9.99 or kill it trying
    My best run to date was at the track rental last month. Car was mostly stock except for a one piece drive shaft and diff brace to keep it from breaking at the track. Will be tuned in the spring with a better tire. Hoping for 9's with bolt-on's
    Date of Run: 11/12/2017
    User handle: Stangman701
    Real Name: Ray
    60' ET: 1.71
    1/8 ET: 7.09
    1/8 MPH: 101.63
    1/4 ET: 10.93
    1/4 MPH: 131.20
    Vehicle (Year, Make, Model) 2015 Dodge Charger Hellcat
    Engine size (Displacement): 6.2L
    Power Adder 1 (If applicable): Stock S/C w/ stock pulley
    Approx. Weight (with driver in LBS): ~4,700
    Track: Keystone
    Trans: Auto (stock or built) or Manual (stock or built): Stock Auto
    Tires (Street, DR, Slick) & Size: 305/35/20 Nitto 555R
    Future goals: 9's with bolt-on's and E85
    Date of Run: 11/02/2014
    User handle: Ares
    Real Name: Ed
    60' ET: 1.57 (been as quick as 1.51)
    1/8 ET: 7.59
    1/8 MPH: 89.48
    1/4 ET: 11.94
    1/4 MPH: 113.64
    Vehicle (Year, Make, Model) 2004 Ford Mustang GT
    Engine size (Displacement): 281
    Power Adder 1 (If applicable): NA
    Power Adder 2 (If applicable): NA
    Approx. Weight (with driver in LBS): 3153
    Track: Keystone
    Trans: Auto (stock or built) or Manual (stock or built): Manual Stock 3650
    Tires (Street, DR, Slick) & Size: Slick, Mickey Thompson 26x10 stiff sidewall
    Fuel (type(s), percent used): Pump 87
    Future goals: Turbo, built 2v 281 gunning for mid 10's but think it may do better.
    Nov 2010
    Greensburg
    1,309
    Date of Run: 6/5/14 and 11/6/16
    User handle: Slowsix
    Real Name: Eric
    60' ET: 2.09 /1.99
    1/8 ET: 8.41 /8.41
    1/8 MPH: 90.78 /86.52
    1/4 ET: 12.81 /12.86
    1/4 MPH: 109.26 /112.67 mph
    Vehicle (Year, Make, Model) 2001 Ford Mustang
    Engine size (Displacement): 3.8 Liters
    Power Adder 1 (If applicable): Turbo (6665 turbonetics)
    Approx. Weight (with driver in LBS): estimated 3200-3300 with me in it
    Track: Keystone
    Trans: Auto (stock or built) or Manual (stock or built): Stock t5 in 2014-16, built Gforce T5 now
    Tires (Street, DR, Slick) & Size: both runs on 315/35/17 nitto nt555
    Future goals: getting a built 4.3 liter stroker, going for 10.99, eventual goal is the stick shift 3.8 record, which is currently 10.41 ET in a 6 speed supercoupe
    Just a little 500 whp V6
    Member 2000GT's Avatar
    Plum, PA
    1,611
    Date of Run: November 2003
    User handle: 2000GT
    Real Name: Sean
    60' ET: Around high 1.7s
    1/8 ET:
    1/8 MPH:
    1/4 ET: 11.73
    1/4 MPH: 119
    Vehicle (Year, Make, Model) 2000 Ford Mustang GT
    Engine size (Displacement): 4.6 SOHC
    Power Adder 1 (If applicable): Procharger D1-SC
    Approx. Weight (with driver in LBS):3600
    Track: The Original Keystone Raceway Park
    Trans: Auto (stock or built) or Manual (stock or built): Stock manual T-45
    Tires (Street, DR, Slick) & Size: Nitto DR 275 45 R17
    Fuel (type(s), percent used): 93 pump gas+
    Future goals: Nothing - it's retired from racing. It is just a cruiser now.
    U.S. Citizen 86GT's Avatar
    Sep 2011
    Monroeville
    323
    Date of Run: 11/12/16
    User handle: 86GT
    Real Name: Ralph Kortyna
    60' ET: 1.721
    1/8 ET: 7.637
    1/8 MPH: 91.72
    1/4 ET: 11.867
    1/4 MPH: 117.43
    Vehicle (Year, Make, Model) 86 Ford Mustang
    Engine size (Displacement): 331
    Power Adder 1 (If applicable): -
    Power Adder 2 (If applicable): -
    Approx. Weight (with driver in LBS): 3350
    Track: Keystone
    Trans: Auto (stock or built) or Manual (stock or built): T56 Magnum (2.66) first gear
    Tires (Street, DR, Slick) & Size: Hoosier QTP 27x11.5
    Future goals:
    Rodeheaver's Hot Rod Shop
    15 W. Cross Ave.
    Masontown Pa. 15461
    724-737-5088
    www.RodeheaversHotRod.com
    User handle: cobraII
    Real Name: Chuck Turocy
    60' ET: 1.5373
    1/8 ET: 6.9879
    1/8 MPH: 97.02
    1/4 ET: 11.0740
    1/4 MPH: 119.71
    Vehicle (Year, Make, Model) 1981 Olds Cutlass ('87 nose)
    Engine size (Displacement): 468 Olds
    Approx. Weight (with driver in LBS): 3250
    Trans: Auto (stock or built) or Manual (stock or built): TH400
    Tires (Street, DR, Slick) & Size: 28" MT Pro Bracket Radial
    Fuel (type(s), percent used): Sunoco 93
    Future goals:Win
    ChuckT
    Sponsored by
    Millerstown Pic A Part
    No one else races?
    ChuckT
    Sponsored by
