Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 78
Thread: Project Silver Bullet
  1. #21
    Can’t wait to see what the Silver Bullet can do!
  2. #22
    converting the hydraulic actuation of the pressure plate to a cable actuated set up.
    The next step in the foxbody conversion ...
    i am am getting jealous of the final drive gear you can run with that 5th. Still love my 4 speed, but never going to be able to put the gear to it like that
  3. #23
    Hopefully soon Ron. Hopefully soon.... I'd like to make it to the SCMC rental on the 28th.
    Not a fan of the hydraulic junk.
    3.25 low gear and a 5.13/5.14 is an overall ratio greater than 16.6. Tire height will calm it down some though. Some in Coyote stock run a 4.71 with a combination of a 3.09, 3.17 or a 3.25 low coupled with a 26" which happens to be very similar to my first gear combo.
    Should be in 5th before the 1/8 mile timing blocks.
  4. #24
    Latest addition. Santhuff double adjustable coil over struts. $2250 new. Got these used off a Cobra Jet s197IMG_20180917_152412_01.jpg
  5. #25
    U.S. Citizen 86GT's Avatar
    Sep 2011
    Monroeville
    323
    That’s the cat’s pajamas, Holy Toledo.
    Rodeheaver's Hot Rod Shop
    15 W. Cross Ave.
    Masontown Pa. 15461
    724-737-5088
    www.RodeheaversHotRod.com
  6. #26
    those struts are so cool I cant wait to see how the strange help my car sixty
  7. #27
    Quote Originally Posted by 86GT View Post
    Always heard good things about that company.
    1.39 on the back tires I'm guessing for your Kiote
  8. #28
    might be able to bump the 2 step up a couple notches with them
  9. #29
    About a 1,000 rpm launch then
  10. #30
  11. #31
    wouldnt you have to install the 2 step BEFORE bumping any notches?
    999 at most, he epoxied the 1,000’s dual closes
  12. #32
    That picture, there’s no room to move side to side ;)
  13. #33
    i just want to know where is reverse ? and we will just have to see if the 2 step is in or not ?????
  14. #34
    hehe, these pistol grips with no pattern and your lost ... it's like mine, it's in there, just not where you might expect it to be.
    and wait ... is that "we will just have to see" a call out? I'll stay on low boost ;)
  15. #35
    im not sure I can even keep up with you at 10 lbs
  16. #36
    More weight reduction. And a SN95 pedal assembly. IMG_20181002_222156_03.jpgIMG_20181002_222205_01.jpg
  17. #37
    This is a vertical gate deal?
  18. #38
    yep just pull and push
  19. #39
    My boss runs the same trans in his stock eliminator car. Said he had an issue with detent from 4-5 that took a while to figure out and fix as trans wanted to go back to 3rd.
    Otherwise been a flawless deal for him.
  20. #40
    The fox pedal assembly just bolt in or something need modded? Looks like a clean fit.
