Lower Front control arms (Did I mess UP??)
My 1990 Notch has a 5 lug swap from a newer Mustang. I ordered these lower Tubular control arms from BMR.https://lmr.com/item/BMR-AA034H/must...k-aa034h-79-93 Can I use these or should I return them? They make ones for 94 and Up. I don't know the difference between the years for Lower control arms. Tried google but no clear info.
Hi! I'M DAKS #1 BITCH!
Stock fox is 13"
Stock sn95 is 14"
If you want to tuck the wheel , run one inch shorter set.
For example i run 12" on my blue notch
Also the threads on the ball joints are different on fox and sn95s. One has threads further down the shaft.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
