Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 87
Thread: New Toy.........
  1. #21
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Stand back suckahz.....
    But.....uh......no turbo.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
  2. #22
    I think that is a 1 of 1 limited edition hi-po Ranger.
  3. #23
    Armagh, PA
    4,331
    I certainly hope no more than one were built. It's a real POS!! But perfect for what I need.
    Ahh fuque
  4. #24
    Armagh, PA
    4,331
    Started working on the keeper last night. Door hinges need repaired/replaced on the driver side. New lowers came with the truck. Top will get a new pin.
    Not sure why pics are posting sideways.
    Ahh fuque
  5. #25
    Armagh, PA
    4,331
    Behold.......
    It's actually really clean under the hood. Lots of new parts were on it.....MSD coil, MSD wires, cap/rotor, EGR, IAC, rebuilt PS pump, reman alternator, new gas tank, tank straps, radiator. Also looks like the valve cover, timing cover and WP had been pulled/replaced at one time. Optima red top came with it. Exhaust manifold has new bolts in it.
    We should name this truck Harley. It burns gas, shakes and makes noise.....but withOUT the harmful side affect of horsepower!
    Set the timing last night at 10 BTDC. Will run smooth then start missing and idle gets faster. Need to sort that out but for now we are hitting the most urgent needs...the driver door not closing properly, battery ground wires need attention and other easy to do stuff.
    Ahh fuque
  6. #26
    I like this truck.....
    Sounds like a vacuum leak.
  7. #27
    Armagh, PA
    4,331
    The ride home for both trucks.
    Ahh fuque
  8. #28
    Armagh, PA
    4,331
    Thanks. It's just going to be a basic, as they came from the factory driver. The frame is freaking awesome...like new. The shifter handle is pretty sloppy, that will get a rebuilt kit. Door panels are shot but I have a matched pair of grey from a newer 89-92 truck.
    I'm letting Colt do as much of the cosmetic and minor mechanical work as possible with just giving a little guidance. We've tinkered on it twice and when we close up for the night he's told me the "to do" list for the next night.
    Thankfully it doesn't need any major mechanical repairs. The only thing that's bad is the passenger side floor pan. The driver side was replaced. The pass side is less than $50...or I can cut one from the parts truck...if it's any good. Probably just order one.
    He's laid claim to it. As long as he keeps interested and asks to work on it then that will likely be the case. And...it will keep him away from the 387W truck.
    Ahh fuque
  9. #29
    Love this Father & Son project!
    Truck is cool too!
    Mild 5.0 swap it and you can tow the 387 to the track with it...
  10. #30
    Armagh, PA
    4,331
    Quick 2.3L question....distributor vs distributorless motors.
    The motor in the blue ranger smokes. It is a distributor style motor. The other two trucks are distributorless. Now, I know virtually nothing about the 2.3's. Are they interchangable? I didn't know if the distrubtorless motors were the same but maybe had a block off plate for the dizzy...or....?? Obviously the heads are different....4 plugs vs 8 plugs.
    Ahh fuque
  11. #31
    Same ish, but no... depends on which way you are going and more specific on the years when it comes to DIS.
    You are right that the DIS block has a plug "dummy shaft" to drive the oil pump.
    The difference is in the front, the DIS block has mounting for the crank trigger while the distributor engine does not.
    For what I think you are asking, You can use the DIS block, remove the crank trigger, remove the dummy plug and install your distributor. Bolt your NA top end on that block and go
    option - The dual plug will have a roller cam with cast roller followers. It is a much better cam than the slider in the distributor engine and swaps right in. (as long as they are cast followers, NOT stamped)
    warning - the auxillary shaft interface is a weak point. mixing and matching parts there is bad juju
    My wifes convertible is the other way, actually an early SVO engine that I modified for the crank trigger, installed the dummy shaft, and bolted the dual plug head on to.
  12. #32
    Armagh, PA
    4,331
    Update.
    Cleaner grill badge. Old one was bothering Colt.
    Vac leak going to the MAP.
    Vac leak to the EGR they tried to fix with tape.
    Horsepower added....
    Door panels updated.
    Seems to be running pretty good now. Well, smooth. It's still gutless. Thinking a rear swap to pick up the RPM's. Shifter rebuild kit will be here today...it's pretty sloppy.
    Ahh fuque
  13. #33
    Armagh, PA
    4,331
    Colt has also done a bunch of little stuff. All of the lenses had overspray on them from a repaint. I had clean marker lights from other parts trucks of the past. So he went around and swapped them in. I've told him to get the seat out so I can start working on the pass side floor pan replacement. He's dragging his feet since he knows it won't be driveable for a week or so. It's not licensed but that doesnt keep him from bombing around the yard in it and the occassional drive in Mexico.
    Ahh fuque
  14. #34
    That muffler is 1/7th of the truck price. :)
    Progress has been made
  15. #35
    So where’s the vid so I can hear my muffler? Million mile warranty baby!
  16. #36
    Armagh, PA
    4,331
    Put your ear up to a conch shell.....sounds about the same!
    Ahh fuque
  17. #37
    Every attempt to change the sound of 2.3 exhaust results in more tractor
  18. #38
    Armagh, PA
    4,331
    Ok...well...took a step back. Found ANOTHER vac leak. Carb cleaner around the middle intake gasket seemed to be the spot. Pulled it apart and the gasket looked good. I'll throw a new one in and see what happens.
    Ahh fuque
  19. #39
    Your sig needs updated to reflect Ranger fleet status.
  20. #40
