Were can I pick it up at. Negitive side of the coil and if so which wire is it (if memory serves I seem to remember a yellow wire and a green wire) or if not there , where.
You can get it at one of those 2 wires Cam. I don't remember off hand which one it is, but it will be the only one that has a AC current, you know the stuff those furnaces & ac's you install use. :D
I will check that out. I can't imagine why there would be a ton of amperage going through the feed wire of the coil, and it's only 12 V going in. It's the job of the coil to create the many thousands of volts that go through the plug wires. Interesting.
EDIT: AC/DC rocks!
Let's just say the 15+ years of Mobil Electronic Installations has been a good teacher on finding a tach signal. I'll never forget the 1st remote starter I put in and probing that wire and getting shocked by it!
Oh yeah, I think Colin is drinking again on a Friday at work!
Low and behold I did measure about 7 volts A/C current on the yellow coil wire. (and about 5 amps). Learn something new every day. Ed you is teh shiznit![]()
Oh, its definatly AC voltage.
