Results 1 to 13 of 13
Thread: Tach signal
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Tach signal
    Were can I pick it up at. Negitive side of the coil and if so which wire is it (if memory serves I seem to remember a yellow wire and a green wire) or if not there , where.
    Robinson
    3,842
    Quote Originally Posted by Cam99 View Post
    Yes, test the coil to see which wire.....but I thought that coupe had an MSD???? If that is the case there is a tack output the ole red box.
    87 GT
    93 Notch
    60 Country Sedan
    Fairlanes/Galaxies 59-68
    67 Contiental 4 door
    06 Powerstroke
    You can get it at one of those 2 wires Cam. I don't remember off hand which one it is, but it will be the only one that has a AC current, you know the stuff those furnaces & ac's you install use. :D
    Melcroft
    4,178
    DC current on the car
    Put your meter on it! Or better yet, grab it while the car is running and tell me if you still think it's DC.
    The tach signal wire on the car is the only wire that can actually shock you. It IS AC Current.
    Robinson
    3,842
    87 GT
    93 Notch
    60 Country Sedan
    06 Powerstroke
    Robinson Twp.
    2,143
    Not sure on the whole AC/DC thing, I would guess it's still DC though just with really high voltage. Ive been shocked by plug wires before too though. I was dumb and tried changing them around while the car was running and a couple of them shocked the shit outta me
    2015 Charger Hellcat
    85 GT
    73 F250
    Lifted, 35's, 460 4spd
    Real name = Ray
    Melcroft
    4,178
    I will check that out. I can't imagine why there would be a ton of amperage going through the feed wire of the coil, and it's only 12 V going in. It's the job of the coil to create the many thousands of volts that go through the plug wires. Interesting.
    EDIT: AC/DC rocks!
    Let's just say the 15+ years of Mobil Electronic Installations has been a good teacher on finding a tach signal. I'll never forget the 1st remote starter I put in and probing that wire and getting shocked by it!
    Oh yeah, I think Colin is drinking again on a Friday at work!
    Robinson
    3,842
    87 GT
    93 Notch
    60 Country Sedan
    06 Powerstroke
    Melcroft
    4,178
    Low and behold I did measure about 7 volts A/C current on the yellow coil wire. (and about 5 amps). Learn something new every day. Ed you is teh shiznit
    Oh, its definatly AC voltage.
  1. Turn signal relay - Help finding
    By roush08 in forum Fox-SN95
    Last Post: 05-13-2012, 09:18 AM
  2. WTB: 99-04 turn signal bulb holder
    By Inkdcountryboy in forum Ford Parts
    Last Post: 10-06-2011, 09:46 AM
  3. wtb Turn signal switch
    By jclose11 in forum Ford Parts
    Last Post: 07-02-2008, 02:56 AM
  4. Old Tach
    By racefan in forum Ford Parts
    Last Post: 01-22-2008, 11:42 AM
  5. svo right turn signal marker light
    By yeahloh95 in forum Ford Parts
    Last Post: 11-10-2006, 09:39 PM
