Results 1 to 4 of 4
Thread: t-bird sc
    Senior Member 89 vert's Avatar
    plum
    487
    Unhappy t-bird sc
    I have a 90 T bird super coupe and I am looking for abs parts (pressure switch, accumulator and pump) The dealer cant locate anything from coast to coast, and all the parts stores dont carry anything for it. If anyone knows of one being parted out, because I have no brakes and don't know what to do> Thanks
    I'm not a lot of direct help on the SC system, but took my knocks on the 87/88 TC system (god awfull).
    If you go to www.rockauto.com, they list parts of the system as available. Not sure if any of that helps you.
    Second, these guys do rebuolds of these systems and sell reman units. It very well might be worth a call for the parts you need. http://www.priorreman.com/index.htm
    Third, I thought all of the Ford ABS units of that era still worked well with the ABS fubared, just no ABS. What the TC system did have problems with, was the relays. There are two relays for the precharge motor, they are really simple automotive relays, and I was able to pick them up at an Advance by crrying it in and not leaving until I had something ;) for that system, if you didnt hear the motor run when you turned the key, it was the relay.
    On Edit - This is another source i use for used parts. sometimes terrible to look up a part, but if they list stuff, it usually means thay have a car. In a case like a SC, you actually might be better to look for a supercharger as a part, then you know trhey actually have a SC rather than a base bird or whatever, then call. http://car-part.com/index.htm
    Sorry this isnt direct help, but maybe some leads to help you out.
    Bob Myers
    plum
    487
    Thanks for the links, very,very helpful, found most of what I am looking for!!
    Glad I could help.
    Bob Myers
  1. T-bird stuff
    By 95gts in forum Ford Vehicles
    Last Post: 10-31-2009, 10:58 PM
  2. Here's some new pics. of my T-Bird
    By 1Badbird in forum Pictures & Videos
    Last Post: 07-16-2009, 04:39 PM
  3. Bird
    By torchred v6 in forum For Sale
    Last Post: 09-03-2008, 06:30 PM
  4. 90 T Bird SC
    By 89 vert in forum Ford Vehicles
    Last Post: 04-08-2008, 10:28 AM
  5. 90 T-bird SC
    Last Post: 06-24-2007, 09:36 PM
