Results 1 to 2 of 2
Thread: Input on this 302 out of the '84
    Messing around tearing block down thinking it was the original motor. I got the heads off and first thing I noticed was the Felpro gaskets everywhere and then the flat top pistons(4 valve notches). I started cleaning off the mess off top of pistons and see they are stamped .040
    Now knowing the short block is a reman(found a very worn sticker on side of block with it saying Beasley Industries No.275806) and that it is a 4.040 bore. I assume it is a late model block since it is machined for the factory roller lifter spider retainer. Will this block still be ok at 4.040 bore? No ridges at top can still see the cross hatch somewhat but it would need honed. Looks to be an old rebuild as timing chain is streched pretty good.
    Belle Vernon
    1,294
    Ed, .040 overbore will still be good but you won't be able to bore it again. If the cylinders still look good I would just clean it up and use it.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
  1. Looking for pistol input ...
    By mr4teth in forum The Bar
    Last Post: 05-13-2012, 11:12 PM
  2. wtb stock 302 standard bore 302 pistons
    By badstanglx in forum Ford Parts
    Last Post: 09-13-2009, 05:29 PM
  3. Exhaust Input
    By Shanehead89 in forum General Tech
    Last Post: 06-11-2009, 03:25 PM
  4. Need some input
    By Stangin in forum General Tech
    Last Post: 10-24-2007, 10:55 AM
  5. Gears!! I need some input.....
    Last Post: 07-28-2007, 10:33 PM
