Results 1 to 3 of 3
Thread: Carburetor Help
    Ninja
    Cranberry
    331
    Carburetor Help
    ok so shortly down the road i will be buying a carb for my engine.i dunno if you guys wanna know but im gonna list the work done to it so you have a feel for where im at. its an 89 302 bored .030 over. Speed Pro forged pistons,Eagle Forged rods,rotating assembly balanced,polished crank, frpp E-303 Cam,FRPP Hardened pushrods,FRPP Roller rockers,stock heads were cut and had a three angle valve job with new valve springs, and an edelbrock performer rpm intake. ok so i also plan on running a wet nitrous system somewhere around a 100 shot or so. i was wondering if i would have to go bigger with the cfm size of my carb due to the nitrous. obviously im gonna go with a bigger cfm than stock but would i have to go even bigger to compensate for the nnitrous?? i was looking at the Holley Street Avenger probably 670 cfm. would that be good? Just looking for some advice before i make this investment. Thanks guys
    If I had to buy another carb I think I would pony up the little extra cash and get a Barry Grant speed demon. They're top notch pieces. I would think something in the 650 range would be good for you so it sounds like your in the right ball park there.
    Ninja
    Cranberry
    331
    thanks stangman ill look into that
    1985 Mustang GT:Cobra r's.full exhaust.8.8 w/ 3.73's.forged 306 c.i..
  1. Edelbrock Carburetor and Weiand Xcelerator Intake Both New
    By onenastytbird in forum Ford Vehicles
    Last Post: 09-19-2009, 12:29 AM
  2. New 750 CFM Speed Demon Carburetor
    By Black Vert in forum Ford Vehicles
    Last Post: 05-20-2009, 10:33 PM
