I'm posting this for a friend of mine.... You can reach him on corral.net here is his origional thread.
http://www.corral.net/forums/showthread.php?t=919598
For sale
1993 SALEEN SC REPLICA VERT
I am moving on to something else. The car was painted last year single stage black along with the engine bay. The car has been garage kept and has never been hit. Ever part on this car is new or in new cond. Car has less then 3,000 since everything was done, chassis has less then 60,000 miles on it. This car was built for cruising, drag racing, car shows, and open track racing
The following is done to the car:
Engine:
Dart block bored to a 306
DSS Prolite 9.2 CR piston
H beam rods
Edelbrock 60379 heads 1.90in 1.60ex. 5 angle valve job, slight porting on the exhaust side
1.6 roller rockers with 7/16 bolts and locking nuts
compcams pushrods
Custom cam for the turbo
FMS double roller timing chain
FMS lifters with explorer hold downs
Holley system Max lower with a ported and polished SALEEN upper
65MM TB and 67mm EGR
MSD Dist with a crane black box
FMS wires custom fitted
FMS Balancer
Edelbrock polished water pump
A lot of polished and chrome parts
custom made AC lines
Power adder and exhaust:
HP Turbo stage II kit, all parts are either polished or jet-hot coated
2.5 cat back with dyno max mufflers
Edelbrock Stainless steel oval exhaust tips
Fuel system
Twin Walbro 225 pumps with tank insert.
push loc fuel lines
Vortech fuel rails
Aeromotive adjustable fuel reg.
42lbs injectors
Cooling:
180 T Stat
Fluidyne Rad
SN95 fan with adjustable controller, all new hoses
Drive train:
3550 trans with Pro 5.0 shifter base, handle is from a 93 Saleen with metal bushings
Spec stage 3 clutch
Lite weight flywheel
FMS Driveshaft
Lakewood driveshaft loop
3:55 gears with Auburn Pro Posi
31 spline Moser axles
Trick Flow rear cover
D & D clutch cable, quad, and firewall adjuster
Brakes:
SN 95 Cobra brake kit. All parts have been powder coated black
braided brake lines
Wilwood pos valve
Hurst Line loc
Body:
single stage PPG Black
Saleen ground effects
2.5 Cowl hood
Saleen 1993 SC stripes
Saleen vert wing
93 Cobra grill insert.....running horse is paint flat black
Wheels:
The 3 piece wheel are not going with the car, I am keeping them
One piece Sterns will be on the car when sold
Plus one set of custom made Bogarts Welded RT rims and MT tires
Interior:
Flofits front seats with matching rear seat cover
Autometer gauges, boost, water, oil, fuel psi, and Tach and shift lite
4pt rollbar
Suspension:
MM coil overs, Panhard, A arms, CC Plates, bumpsteer kit with alum. rack bushings, and MM lower rear control arms
Tuning:
Anderson PMS new style
Ugeo Wideband
Datalogger software
$23,000.00 firm
