Results 1 to 2 of 2
Thread: coilover quesiton
    Banned George C's Avatar
    1,490
    coilover quesiton
    i installed my coilovers on the font of my notch. i lost the instructions from years ago. they were installed on my hatch but when taking them off the hatch they came apart
    now one question is if i installed it correct
    on top of the coil is the collar, then 2 thin shims, then a bearing shim, then the top, then i have a 1/2 gold spacer, then a larger spacer that is taperd towards top which seems to work with my steeda CC plates.
    just want to make sure this is correct
    also another question is i drove it and i realize i need to bump them up some in height since its bottoming out some. right now i have the car sitting from ground to fender lip 25 5/8"....what is the typical height from a fox?
    also noticed well driving it seems that hte coilovers are clunking when turning. i heard this sound before when i had my cavailer when the bearings for the struts were bad. but is the sound im hearing from the coils being set to low? or did i put the top of the coilovers together incorrectly?
    also how much clearance do most ppl ahve betwen their tires and the coilovers? i have 235/55/16s and it seems to rub slightly. i eye balled my alignment for now
    all help would be appreciated
    1,490
    figured it out. raised the car up to 26 1/2" and got rid of the issues i had. coilovers ride so much nicer then the springs
  1. Brand new Team Z lower coilover mounting brackets.
    By NOVICOUPE in forum Ford Vehicles
    Last Post: 03-31-2011, 09:46 PM
  2. Pedders Coilover Install
    By thedak in forum General Tech
    Last Post: 01-29-2011, 07:00 PM
  3. wtb front coilover kit for foxboby
    By badstanglx in forum Ford Parts
    Last Post: 09-19-2010, 06:26 PM
  4. Front Coilover/CC Plate Installed
    By street591 in forum Pictures & Videos
    Last Post: 04-28-2010, 01:21 AM
