Results 1 to 5 of 5
Thread: Big thanks to Mike (Map351)
    LowHill
    2,679
    Thanks again to you and your boy for all you did on it, and I'm sure I'll be calling with more questions too.
    2.3T ---- IT'S ALIVE
    Leechburgistain Mainland,Cuba
    1,534
    Lightbulb
    I think we got it figured out now! I forgot about the TFI.....
    289 slabside cobra
    6S1941
    LowHill
    2,679
    ohh yeah i got one to give you, I forgot it.
    1,534
    Progress report?
    289 slabside cobra
    6S1941
    LowHill
    2,679
    hooked up boost valve and boost gauge, buttoned up all the vac leaks, changed plug wires and got rid of it sometimes hitting on 3 holes. Turned the dizzy alittle and got it to idle alittle lower but has a nasty miss between 3500 and 4000 at 15lbs, but under that pulls real hard. So I found the timing cover just got to get it Friday and the alt started whining so got a guy putting bearings in it. I also regapped the plugs from 32 to 28 and cleaned the Tb and IAC real good, so as soon as I can get the timing cover on and alt back on I'll try again. And I lost your cell # Mike, Pm me it if you get a chance. Thanks Shaun
  1. Thanks Mike.
    By 95V6 in forum Wolfpack Speed
    Last Post: 06-07-2010, 12:10 AM
  2. Thanks Mike!
    By ModularMike in forum Wolfpack Speed
    Last Post: 05-03-2010, 12:21 PM
  3. Thanks again Mike!
    By weareweird69 in forum Wolfpack Speed
    Last Post: 05-30-2009, 02:26 PM
  4. Thanks Mike
    By blackfive-o in forum Wolfpack Speed
    Last Post: 05-05-2009, 06:33 PM
  5. Big thanks go out to Mike & Jon Lund
    By Sonic03snake in forum Wolfpack Speed
    Last Post: 03-31-2009, 10:42 PM
