i have a built AOD for sale. its a GER strip/street AOD. it comes with a trick flow deep pan, comes with a Lentech auto/manual Valve body. whats nice about this Valve body is it has electric lockout for OD. your stock shifter works with this setup. L is now first, D is now 2nd and OD is now 3rd. trans will fall into OD if you have the lockout unpowerd. if you have the 12v+ applied to it, you wont see OD which is nice since most AOD racers manually shift the trans. It also comes with a GER 3200 converter
the trans has about 10k in miles on it and was only at the track twice
im asking 800 obo...as for shipping we can work on it. might even be able to deliever it if close enough to Pittsburgh PA.
PM me with offers since i dont search classifeds much.
trans was also color matched in 88 charcaol gray
