Results 1 to 4 of 4
Thread: Vacuum Lines
    North Hills
    1,229
    Vacuum Lines
    not 100% what i should be pulling at vacuum at idle on my car, but im seeing about 10 on my gauge and idle is very low/choppy. i "think" it used to be close to 20, but since i added the 1" spacer between the manifolds, my vaccum/idle seems to be all off. i treid changing the TPS and cleaning the IAC so far also.
    on the Vacuum tree, i see that one of the lines/caps has fell off or is missing. what goes to the "B/R" spot on the tree. i have:
    -BB runs to the brake booster and is connected
    -S/C is capped, should i run my boost gauge to S/c possibly?
    -A/C run accross the firewall to what looks like another vacuum tree
    -B/R was missing, but i capped it and didnt seem to make much of a difference
    -and S runs to my upper intake manifold.
    Also, i have a mystery Vaccum line that streatches the firewall also. dont know where it goes, but it looks like the origin is the fenderwell behind the passenger shock tower? its hard black plastic and what looks to be a "bigger" vacuum line. i "dont think" it was hooked up before, but i could be wrong
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    what kind of a car do you have and year and more info what all is done to your car .
    my br is caped as well as my s/c which if you own a fox body mustang run out to the cruise control. mine is gone that is why it is capped my vacum at idle with my cam is between 8-10 i can watch it on my gauge but mine is low becuse of my cam
    North Hills
    1,229
    Sorry.
    87 GT.
    Maf car. H/C/I/S-trim no cruise. 5spd
    maybe the cam is what is keeping it low, but at low RPM's it runs like total crap. and seems to only be since i put the intake spacer in.
    North Hills
    1,229
  1. vacuum line question
    By crazylou in forum General Tech
    Last Post: 03-26-2011, 06:39 PM
  2. 5.0 vacuum lines
    By PSPstang in forum Ford Parts
    Last Post: 03-21-2011, 01:00 AM
  3. Older carbed 5.0 vacuum lines?
    By jclose11 in forum Fox-SN95
    Last Post: 10-21-2008, 10:28 PM
  4. Does this look like a vacuum leak?
    Last Post: 09-11-2008, 05:41 PM
  5. any experts about vacuum??? need help!!
    By slo95 in forum General Tech
    Last Post: 08-19-2007, 10:30 PM
