Results 1 to 10 of 10
Thread: Drag front suspension on the street.
    Who is doing something crazy with their fox like this? I have the front half of the eibach launch kit to install on my Capri. i have been hestitaing becasue I do drive this thing a lot.
    Anyone have experience with launch springs on the front of a driver?
    How about 90/10 or 70/30's on the street?
    How bad is it without a sway bar?
    Any impressions are appreciated. I'm going to try the springs, I think thats fine, but how far can I go with some of this other stuff???
    Bob Myers
    next time your at the track
    just take my car for a drive. it's no raod race car. but I drive it 10k or more a year......
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    Robinson
    3,842
    Here is what the notch has.
    90/10 fronts
    Ground Pounder springs front and rear
    Double Adjustable Steeda Uppers - rear
    UPR lowers
    LMM box reinforcements.
    The car is fine on the road. I have driven worn-out foxes with stock suspension. that handled worse. I drive the notch on the road a bunch. Do it, it wont be too bad.
    87 GT
    93 Notch
    60 Country Sedan
    Fairlanes/Galaxies 59-68
    67 Contiental 4 door
    06 Powerstroke
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    I have Moroso trick front drag springs on the front of my car along w/ Lakewood 90-10's and NO saybar, and manual steering and its not bad at all.
    Corvette Z06
    GREEN=FAST sweeney1030's Avatar
    johnstown
    570
    hey man the guy that owned your capri in Indiana called me and asked about your car if it was still around ,he heard I knew of it , I told him it was but now its FAST he was happy to hear its still alive. keep the sway bar its off the SVO donor if its still the same one . 90/10s sucked on my 84 stang notch turbo (also a transplant but from a 88 turbo t-bird). there was,nt enough weight for them to help much but your car is heavier than my notch so maybe they will help good luck . Jack
    KB 2.6 custom fabbed
    Southern California
    311
    I think 90/10's would get really old on the interstate. As for the rest, i don't think you would regret it.
    Mr. 331 N8Miller's Avatar
    Dec 2006
    Kingston, PA, USA
    239
    i deabted going 90/10s becasue i really only go like 2-3k miles a year. but with a 2-year-old in the car, i comprimised for 70/30s.
    you will be happy with it if you just want it to hook.
    1986 GT:331, Edelbrock Vic Jr heads, Jay Allen custom cam, TFS R intake, 30# injectors, 75mm t-body, 80mm PRO-M, AFM Powerpipe, BBK 1 3/4 long tubes, BBK X pipe, 4.10s, 5 lug conversion, 99GT rims/Nitto DRs, PBR brakes, Lakewood 50/50s, Moroso rear drag springs, Sub frames, 2.5" cowl, Saleen spoiler
    Power of a low 12 second car, Traction of a high 14 second car!
    Thanks guys! I'm going to put the springs in this week, and yank the sway bar and give it a try. If thats not too hairy, I will add the struts.
    I just need to get the front freed up on this thing ;)
    Bob Myers
    Quote Originally Posted by sweeney1030 View Post
    Tell him to stop up the track someday and see it now. He might not recognize it, MAP changed a lot around when he had it, and I've changed a lot from when MAP had it. It is still all SVO underneath, but now 8.8 and aftermarkets arms. Front is still the heavy SVO stuff.
    Bob Myers
    At the racetrack
    4,193
    The swaybar will have a greater effect on your handling than the struts will.
    Atleast it did on my car.
    Corvette Z06
  1. Drag car suspension
    By Inkdcountryboy in forum General Tech
    Last Post: 10-13-2009, 10:01 PM
  2. 07 front suspension front thunking noice
    By 07vbluestang in forum S197
    Last Post: 04-22-2009, 10:33 PM
  3. Front suspension parts
    By Martin0660 in forum Ford Parts
    Last Post: 10-18-2008, 12:00 PM
  4. SN95 front suspension
    Last Post: 11-19-2007, 12:52 PM
  5. Drag Suspension For Sale
    By thelast50ho in forum Ford Vehicles
    Last Post: 10-29-2006, 07:37 PM
