Results 1 to 10 of 10
Thread: Future Mods
    Member RUSH2112's Avatar
    Hopewell, PA
    754
    Future Mods
    I have been thinking about doing some future mods that will be relatively cheap.
    Obviously the most noticable mods are H/C/I (heads, cam, and intake)
    I have recently replaced my stock intake with the cobra intake, which has a little better flow over stock.
    Since heads are too pricey, I figured on dropping a cam in to wake up the car a little.
    What else might I need besides a cam to rattle my brains when I stomp on the gas?
    North Hills
    1,229
    bigger MAF, bigger throttle body,
    used heads?
    Power Adder
    236
    Ahh if you going with the trouble to swap cam, it's time for heads!! Look for a cheep set of steel GT-40 heads or a used set of aluminum heads. I had an e-cam with stock heads and GT-40 intake and the power band just fell off hard. The heads couldn't flow enough and the valve were more than likely floating with the stock valve springs. She sounded good with the cam, but the car couldn't back up the sound ;) Now with the trick flow heads on her....wow what a difference!!
    Chris Kauffman
    1988 408LX drag car
    LowHill
    2,679
    I agree, if your doing a cam pick up a set of used heads or even get the stock ones ported.
    Aftermarket cam + E7TE's = bad move and perhaps loss of power. I wouldn't put one red cent into porting E7TE cylinder heads. As suggested above find some GT40 P's if you wanna do it on the cheap OR invest in some aluminum castings from the numerous offerings available from the aftermarket. Total Engine Airflow (330-634-2155) has been producing top notch TFS products and can provide you with a cylinder head(s) to meet your needs.
    -Joe
    Hopewell, PA
    754
    Ok, so I have heard this combo will be nice, all while retaining the stock heads:
    B303 Cam
    24# injectors
    65mm TB
    76mm Mass Air
    1.7 rockers
    Member bspilner's Avatar
    Jun 2007
    Fox Chapel
    63
    I have everything your looking for, power heads w/ pushrods (www.powerheads.com); steeda #19 cam; 80 mm pro m, 70mm bbk throttle body and 24lbs injectors; 1.6 roller rockers!
    Hopewell, PA
    754
    I might be interested in the BBK throttle body. How much?
    Hopewell, PA
    754
    Quote Originally Posted by bspilner View Post
    I got a line on #24 injectors. I don't want the heads and I am looking for 1.7 rockers
    Is the steeda #19 cam comparable to the B303 cam?
  1. Your Future....
    Last Post: 10-19-2009, 09:01 AM
  2. This little guy has a promising future....
    By somethingclever in forum Pictures & Videos
    Last Post: 08-27-2009, 11:16 PM
  3. Could GINA be the future?
    By Flyin Monkey in forum The Bar
    Last Post: 06-13-2008, 12:48 AM
  4. FUTURE parting out thread, 87 GT h/c/i EVERYTHING
    Last Post: 06-21-2007, 08:04 AM
  5. Future Track Rentals
    By stanggrrl in forum The Bar
    Last Post: 10-16-2006, 12:50 PM
