I am thinking of setting up another motor.
306 roller block
Stock lifters
AFR 185 Heads with upgraded springs and valves
CompCam XE266HR
Crane Aluminum 1.6:1 roller rockers on 7/16 studs.
Gt40 upper and lower intake
2.5 inch exhaust
3.73 or 4.10 gears
I have a basic idea how to build and use an adjustable push rod when used with an solid lifter, but how do you get the valve train geometer correct when the hydraulic lifter is not pumped up. And if you manually pump up the lifters and put them in the block, won't they collapse when you spin the crank? Thanks for the help.
