Results 1 to 11 of 11
Thread: Mass Air Flow Sensors???
    Looking for an air meter that is close to 80mm in size. What manufacturers do you suggest? Any real world experience with a certain brand/size? Currently I have a C&L 73mm M.A.F. This is for a N/A 302 H/C/I
    -Joe
    North Hills
    1,229
    i have a SCT one that i like. but probably need a chip to use it due to match the injectors
    I definitely do NOT suggest C&L. They are worthless IMO. My dad switched from a 76mm C&L to a PMAS 80mm unit and it solved a lot of issues with the car. The car was more repeatable on the dyno and it could actually be tuned. With the C&L it was a stab in the dark how the car would react pull to pull. I hear good things about the SCT one but as blkp42e stated you will need a chip/tuner to go along with it as it doesn't come "matched" to any certain injector size creating the need for you to create your own MAF transfer function inside of the EEC.
    Got Boost?
    West Mifflin
    1,442
    I second the PMAS 80mm unit. I run one and it works excellent.
    1994 Rio Red GT
    10.60 @122.88
    Sold
    Power Adder
    236
    Paul where did you and your dad get the mass air meter from?? Thanks bro!
    Chris Kauffman
    1988 408LX drag car
    Anderson if I'm not mistaken. He was a little higher price than others at the time, but my dad had a dyno day setup at Kauffman's and needed it as soon as he could get it. At the time Anderson was the only place with them in stock.
    http://www.professionalmassairsystems.com
    Someone recently told me that they no longer offer a 80mm unit, and from the looks of it that may be right. It looks like they have a 95mm setup now.
    http://www.flowmanagementunlimited.c...&cPath=1_2_372
    SCT 2400 or SCT 2800, very nice pieces, I run the 2800 and like it.
    pro-m 80 here and it works great .
    Quote Originally Posted by Rio94gt View Post
    X3! I thought you were running a SD setup.
    BTW, check on the Corral. There are usually alot of them for sale on there.
    North Hills
    1,229
    i had no problem with my C&L when i had one
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    I purchased a custom cal'd PMAS 95mm and couldn't be happier. Best $320 I've ever spent. Previous meter was 76mm c+l, PMAS is worlds above it.
  1. C&L 73mm Mass Air Flow Housing W/ 30lbs. Calibration Tube
    Last Post: 12-12-2013, 12:40 PM
  2. Mass Air Flow sensor needed!
    By LatrobeStang01 in forum Ford Parts
    Last Post: 08-31-2009, 10:11 AM
  3. WTB stock 94-95 cobra mass air flow meter
    By 94svtcobra in forum Ford Parts
    Last Post: 08-04-2008, 09:26 PM
  4. >>>55 mm Mass air flow meter LOW MILES<<<
    Last Post: 03-05-2008, 02:11 AM
  5. pro-flow 80 mm mass air meter
    By SUPRAGATES in forum Ford Vehicles
    Last Post: 02-21-2007, 10:18 AM
