Results 1 to 7 of 7
Thread: sc w/high compression is it possible?
    Bridgeville
    1,278
    Cool sc w/high compression is it possible?
    like the title says seen high comp sc in mag an was wonderin with a lil over 10:5:1 can it be done
    Power Adder
    236
    If you run a high octane race fuel, perferably with an intercooler of some kind, and limit the timing, then yes you can. If you don't have all of these then you'll usually have to limit the boost also.
    Chris Kauffman
    1988 408LX drag car
    boost and high compression do the dame thing is essance, they create more cylinder pressure, which makes more power...
    Member chevydad's Avatar
    latrobe
    281
    get a custom ground cam to help bleed off some cylinder pressure.
    Farmington WV
    4,672
    Quote Originally Posted by PunisherStang View Post
    talkin about the latest 96-98 GT with 600+ hp in the new 5.0?
    was a good article.
    Bridgeville
    1,278
    well besides spraying the car the best thing would b stage 3 or bigger cams i got crower stg 2 now
    ANYTHING can be done. As has been said, its really a matter of how can you fuel it for the end effective compression. As Tim said, boost really just raises the effective compression when you simplify it. Its not the end answer, but thats a good simplification.
    To give you an example, my little 2.3 is 8.0:1 compression at 25 psi boost, altitude has an effect here to as it changes out pressure ratio. My car look like this....
    Boost and Altitude Correction to Compression
    You are running 25 PSI of boost at an altitude of 1300 feet. Your motor's static compression is 8.0 :1. At this boost level and altitude your effective compression ratio is 21.35 :1, and without altitude correction your compression ratio would be 21.61 :1.
    PRP is a true 130 feet elevation, but most times we race at something like 2600-3200 feet. Go down to Cecil, or out to Atco, its a little different game with the mine shaft air they get. Also the altitude will reduce your need for octane a little, but will hurt power.
    You can play with a calculator here if you like:
    http://www.rbracing-rsr.com/compression.htm
    Plugging in your 10.5:1 at 1300 feet, it looks like 12 psi could be managed with good gas, great intercooling, and a safe tune........
    You are running 12 PSI of boost at an altitude of 1300 feet. Your motor's static compression is 10.5 :1. At this boost level and altitude your effective compression ratio is 18.81 :1, and without altitude correction your compression ratio would be 19.07 :1.
  1. Why build a high compression motor?
    By DRRummel in forum Fox-SN95
    Last Post: 12-01-2011, 11:00 AM
  2. Compression question
    By jaa55 in forum SN95-New Edge
    Last Post: 03-09-2010, 02:12 PM
  3. Compression Ratio
    By burntire in forum SN95-New Edge
    Last Post: 12-12-2009, 12:22 AM
  4. Compression
    By Hawkeye in forum General Tech
    Last Post: 01-19-2009, 04:51 PM
  5. New best for my 9:1 compression NA 331...
    By Killercanary in forum Drag Racing
    Last Post: 11-24-2008, 11:29 PM
