Thread: supercharger help.
    Pittsburgh, Pa
    459
    supercharger help.
    Has anyone come across a roots style supercharger setup for the 99/01 cobras? Every kit I have found is marketed towards the 03/04 and labeled as an upgrade kit, or for the 05+. I called Kenne Bell and was told they don't make a kit for those years, BUMMER. So I was thinking,,,,,,, convert to an '03 setup and run the M112 for now. Then having all the upgrade options down the road? Is this just a bad idea or should I start collecting parts?
    Any of you Terminator guys converting to a turbo soon??
    KB 2.6 custom fabbed
    Southern California
    311
    Sheetmetal intake is the way to go. You will be way over 3k just to get stock parts for the swap. I've looked at just about every option for blower set-ups on 4 valves and it crazy how much used factory parts are. Spend $1500 for a used intake and blower, and another thousand in intercooler parts and fuel delivery. Add the cost of 03/04 used heads, and you have a stock cobra motor that is limited with a Eaton blower on top.
    Pittsburgh, Pa
    459
    Taylor, I know what you mean about the cost of rounding up parts, but I dont see another way around this. But I will not be limited to an '03/04 cobra motor in the end. I have to decide what style power adder I am gonna use before I can order my shortblock. Like I said, I am really liking the roots style charger but I wanna make sure it is a doable thing, reasonably, before I go that route. If I can't, then I wanna know NOW, u know.
    NEWB
    167
    http://www.kennebell.net/supercharge...ra_99-014v.htm
    kenne bell makes on for the 99-01s and kenne bells are the shit. the only reason i knew they made one is cuz im gonna be buying the 2.1 for my gt soon. i spend too much time on their website.lol
    2001 Black Gt 5spd
    Kenne Bell is my BOY
    Southern California
    311
    I just picked up a Kb 2.6 for my truck and can't wait to run it. People are making close to 700 on the wheels with 2v heads. I can't wait to see what it will do when i put the 4v's on it.
    Built, Cammed, CCW'd SVT NateSVT's Avatar
    Monroeville
    856
    http://www.svtperformance.com/forums...d.php?t=180943
    Q: Can I easily bolt up the eaton m112 from an 03/04 onto my 99/01.
    A: Well, yes and no. Physically it will bolt up, but its not that simple. You will need a lot of parts, such as the blower, the intercooler, the heat exchanger, the intercooler pump, the secondary blower belt bracket, the crank pulley and bracket, another tensioner, all the bolts and brackets, and a way to relocate the alternator. Its not an easy bolt on. It will work, and make good power, but by the time you are done (even if you get the blower for steal) you will be up to the cost of the vortech, and you will still have an inefficient blower that pushes nothing but hot air about 14 psi. Also, the instant boost from a roots blower combined with the 9.85 compression may be difficult to tune for and could be hard on the stock bottom end.
    2004 SVT Cobra - sold
    2000 Yamaha R1
    2006 Yamaha R1 - Raven
    10.89 @ 127.6 1.61 60' with a ported Eaton
  1. supercharger
    By 08stangftw in forum Fox-SN95
    Last Post: 09-22-2010, 09:21 PM
  2. new supercharger!
    By Tom in forum S197
    Last Post: 01-07-2010, 11:58 AM
  3. what supercharger should i do?
    By Gray 5.0 in forum Fox-SN95
    Last Post: 12-13-2009, 09:37 PM
  4. supercharger F/S
    By jaa55 in forum Ford Vehicles
    Last Post: 10-12-2008, 07:22 PM
  5. Help with Supercharger?
    By Black87GT in forum General Tech
    Last Post: 03-11-2008, 09:01 PM
