How low can I go on my 95 GT before I need to get Caster/Camber plates or anything else?
1.5" Or So
general rule i have always heard and used is 1.5"
Yep, or cut 1 coil off yours.
its depends how much you drive it. i got sportlines but i dont drive it too much so im not worried about the tires wearin out. if you gonna drive it alot def get the caster plates cause it just doesnt align right without them
I dropped my cobra about 1 1/4" and realized you get almost NO adjustment from the factory plates. I always thought you could drop it 1 1/2" up front and get enough out of the plates to be OK. Guess NOT!
need cc plates and off set rack bushings to do it right
which reminds me,,,,, When are we gonna FIX MINE MIKEY?????????![]()
i would try a .400 offset rack bushing first then go to a bump steer kit, the offset rack bushings will work better with the bump steer kit.....less spacers=less deflection
