Results 1 to 20 of 22
Thread: problems with lights
    Belle Vernon
    1,294
    I was driving my car last saturday night and the dash lights and rear parking lights quit working, but the brake lights were still working. Does any know what the problem might be?
    Thanks
    Mike
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    Check for a meltdown of the connector at the turn signal switch.
    Mt Pleasant
    2,916
    check the fuses first
    south hills
    21
    where u running your fog lights?
    1st check fuses then the swich.
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    i have a switch let me know if u need one
    Belle Vernon
    1,294
    I'm going to check the fuses tomorrow but I don't think that will be it. Which switch are you talking about, the head light switch or the dimmer switch? I was leaning towards the switch also but I wasn't sure if it would do something like that.
    I wasn't running fog lights.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    shaler,pa
    1,010
    The headlight switch is always what goes bad in the foxes but normally first sign is when headlight shut on and off when running driving lights. but like Ed said had combo switches go bad also they carry a big load and stock foxes suk on charging.
    89 Mustang (stock) DD
    82 Trans Am (not stock)
    98 Audi A4 (not so hurting)
    Typically yes, but most people don't bother to check the turn signal switch on the column cause they don't realize all the wiring for the headlights goes thru that switch.
    Belle Vernon
    1,294
    Well the fuses are good and so is the headlight switch. I think it is the switch with the wheel to dim the dash lights because it was acting weird for awhile now. Has anyone ever had problems with it?
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    shaler,pa
    1,010
    Yea they go bad replaced a few and had the plug that goes into it melted like Ed said.
    Member bspilner's Avatar
    Jun 2007
    Fox Chapel
    63
    fog light switch
    Did you pull the column apart and check the turn signal switch?
    Belle Vernon
    1,294
    I pulled the column apart but I don't see any visible evidence to a melt down.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    Farmington WV
    4,672
    i did as well..and didnt see any meltdown....but im going to buy a new turn signal and headlight and dimmer switch to see if that fixes it...will make it easier to sell.
    sometimes it is very minor, but it doesnt take much to mess up electrical.
    Lovin my 302
    Chicora, Pa
    116
    I just went through this my dash lights and tail lights were not working but all others did, I found it was my headlight switch and plug they were melted together, You said you checked your headlight switch but we have the same symptoms
    Belle Vernon
    1,294
    None thing looks melted and I did change the headlight switch and it didn't work. The dash lights started going out about two years ago but if I played with the dimmer I could get them to come back on but that doesn't work anymore. I'm going to buy a new dimmer switch they're a $130 and if that doesn't work then I'll buy the turn signal switch.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    If you want to bring the car out to my Dad's in Rostraver on Saturday, I have another dimmer switch you can try before you go spending $130 for another one. I think I might have a turnsignal switch you could try also.
    Belle Vernon
    1,294
    Yeah I would appreciate it. I have it taken apart so it should only take a couple minutes and you could take a look and see if you see anything.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    Belle Vernon
    1,294
    Thanks to ViperED my lights are working again. It wasn't any bad switches. Ed found some bad wiring in the dash and got it fixed up and it didn't cost me a penny. Thanks again Ed I would have spent about $250 in new switches and and wasn't that.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
  1. t5 problems???
    Last Post: 05-10-2011, 05:51 PM
  2. Replies: 7
    Last Post: 05-16-2010, 02:06 PM
  3. problems with idle
    By to50 in forum General Tech
    Last Post: 05-03-2010, 07:23 AM
  4. clutch problems
    By stanggt94 in forum General Tech
    Last Post: 02-10-2009, 11:37 PM
  5. Transmission problems
    By xxtorinoxx in forum SN95-New Edge
    Last Post: 08-26-2008, 11:37 AM
