Results 1 to 8 of 8
Thread: Fox body parts for sale here
    Factory Mass air meter for sale. 30,xxx miles on this excellent piece.
    $25.00
    1993 cooling fan/fan-clutch
    EXCELLENT condition. No cracks in fan blades. fan clutch will engage and dis-engage appropriately.
    Make an offer.
    Stock 87-93 upper/lower intake
    * Upper/Lower intake, 60mm Throttle body and EGR from 1993 5.0L; 30,xxx miles
    * Make an offer.....
    1993 LX/GT stock steel hood
    Steel hood painted factory red. Excellent condition with great paint and no dings.
    Make offer.
    5.0L FOX BODY braking system 4 sale
    * All parts listed below have 30,xxx miles on them.
    * Calipers w/ pads, lt./rt. sides w/ rubber hoses
    * Original Ford Rotors(cut once) no warpage in present state (10.87" diameter)
    * Rear Drums
    * Backing Pates w/ wheel cylinders
    * Shoes and hardware for Rear drums
    * Proportioning Valve
    * Parts were removed because of installation of Manual brakes, and Aerospace Components drag race kit.
    K&N replacement filter for 94-95 5L
    New in box. Twenty Bux
    MOROSO trick front springs 4 sale
    * One wrap and a half cut from the 2nd pair of Moroso trick front springs--> $ 35.00
    * These springs are in great shape as well.
    *Moroso "Trick" Front Springs are designed for maximum weight transfer. Trick Front Springs are tall, small wire diameter coil springs that hold a great amount of stored energy for instant weight transfer.
    Summit sells these new for 104.95.......
    (94-95) PIH harness with computer
    Found this conversion harness among all the other parts I have to replace the "finicky" 1994-1995 ECM with a pre-1994 unit.
    Make a reasonable offer if interested.
    HAL 175/14 Coil-Over Springs 4 sale
    * Coil-Over Springs, 175 lbs./ in. Rate, 14 in. Length, 2.5 in. Diameter, Silver Powdercoated
    * Springs have 10 passes on them.
    * Removed due to combination change.
    * $35.00
    New Centerforce clutch disc
    *Centerforce Performance Clutch Discs
    *Clutch Disc, Organic, 1 1/ 16 in. Diameter Shaft, 10-Spline, 10.4 in. Diameter Disc, Ford/ Mercury
    *Part # CTF-381021
    *Summit=84.95
    $ 60.00 (NEW IN BOX)
    Anderson 3.5" N/A Power Pipe
    *86-93/ 73 C&L, Pro-M 75 Bullet-3.5"
    *AF-0104C
    *Anderson sells this for 185.00
    $120.00
    TFS Upgraded TRACK HEAT valve springs,retainers,locks
    These springs have been used to idle engine, run on a dyno 4 times and then pulled off because of cam change.
    * 1.460" o.d. double spring with damper
    * 125 lbs. @ 1.780" installed height
    * 376 lbs. @ 1.180" open
    * 420 lbs. per inch rate
    * .600" maximum valve lift
    * Valve Spring Retainers 10 degree x 1.50" o.d. chromoly steel
    * 10 degree locks
    New these are 194.95
    $100.00
    1993 grey articulated cloth seats Driver pwr.
    For sale:
    Pair of 1993 grey articulated cloth seats. Driver side is power. Excellent condition with no rips or stains. No gangsta lean with the drivers side
    $200.00 takes the pair.
    Fox Lake stage 1 ported Track Heat EFI intake
    Track Heat EFI, Aluminum, Silver Powdercoated, Multi-Port, Ford, Mustang with Fox Lake Stage 1 port. 20 cfm gain over out of the box.
    511.95 per summit racing for EFI intake&plenum
    150.00 Fox Lake porting
    661.95 Total
    $450.00 for an intake that generated 11.3's@over 118 mph in a 3100lbs. Fox body 302 Naturally Aspirated streetable combo! Like new condition
    19 lbs/hr. injectors ONLY 30,000 miles on 'em
    8 19 lbs/hr. injectors for sale. EXCELLENT condition.
    $40.00
    >NEW< MPG 5-Liter Windage Tray Kit
    Since it is fundamental that efficient lubrication systems help keep the crankshaft free of unwanted oil, the use of this special windage tray kit is necessary for maximum horsepower.
    This style windage tray is designed to quickly disperse oil leaving the connecting rods and main bearing areas so the large drops of oil do not bounce off the interior of the oil pan back into the spinning crankshaft.
    The tray is made of lightweight 18 guage steel and features a built in adjustable scraper, using a precision contour to create the correct scavenging effect, while improving oil drainback.
    Our heat treated grade 8 extended main cap bolts and nuts are supplied in the kit making this a totally bolt on windage tray with NO other modifications required!
    MPG=89.95
    Bolt on 12 horsepower retaining the stock pan
    $75.00 shipped
    Gears,driveshaft,t-5 Bellhousing,axles, Etc
    Used 3.27 cogs from a 96 GT that have 15,xxx miles on them. Excellent condition.
    * $40.00
    Stock steel driveshaft from a 1993 GT 30,xxx miles.
    * $50.00
    28 spline stock axles, great condition, 30,xxx miles.
    * $20.00
    28 spline 8.8 Traction-Lok unit, Excellent condition, 30,xxx miles.
    * $40.00
    Double Hump cross-member. Rubber bushings in GREAT condition.
    * $40.00
    NOS Big Shot EFI wet 150-300 shot
    NOS EFI Nitrous Oxide Systems
    Nitrous Oxide System, Big Shot, Wet, 150-300 hp, 10 lb. Bottle, Blue, Ford, Mustang, 5.0L, Kit
    Brand new in box with a FULL bottle. This kit is designed for the stock intake.
    $500.00 Summit advertises this kit for 659.95
    http://store.summitracing.com/egnsea...115+4294840126
    Part Number NOS-02119NOS
    16 Comp cams part #26918 BeeHive springs, etc.
    Comp Cams Beehive springs, 7* steel retainers, steel locks, and springs cups to properly locate the 26918's in a T.W. cylinder head.
    Great condition----- make a reasonable offer
    TTT
    Also have two A9L's for sale. Make an offer on these.
    fan
    do u still have the fan for sale?
    ttt.
    is sold.
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    got any pics of the anderson pipe? I am very interested!!
    Charleston, WV
    46
    Springs are sold :)
    Bump for a good seller.
  1. Fox body parts for sale
    By matty g in forum Ford Vehicles
    Last Post: 12-05-2013, 12:43 PM
  2. Fox Body Parts For Sale
    By 89mustang5.0 in forum Ford Vehicles
    Last Post: 05-18-2012, 10:19 PM
  3. Fox body suspension parts 4-Sale
    By bad88t-top in forum Ford Vehicles
    Last Post: 01-30-2010, 09:55 PM
  4. fox body parts for sale
    By ryan319 in forum Ford Vehicles
    Last Post: 07-16-2008, 07:49 AM
  5. Fox Body Parts For Sale
    Last Post: 03-18-2008, 11:30 AM
