Results 1 to 17 of 17
Thread: 95 Turbo GT
    1,037
    95 Turbo GT
    This is a buddy of mine in AZ.
    Maybe somone would be interested in PA?
    Link to the thread
    http://www.highperformancestangs.com...ead.php?t=3344
    331ci stock block with 5300miles on it (just freshened up last summer)
    Eagle rotating assym
    Total Seal File Fit Rings (for boost application)
    Clevite bearings
    8.5 c/r JE Pistons Inverted dome
    4340 H-beam Rods
    4340 Crank
    ALL ARP fastners throughout rotating assym
    FMS Billet Girdle
    Milidon 7qt oil pan
    Lokar dipstick
    TFS TW cylinder heads Stg 2 ported (306/220)
    Cometic Headgaskets
    1.6 TFS stud mount roller rockers
    TFS chromoly pushrods
    Cam Motion custom cam (.542/.565 226/232 114)
    Holley Sys Intake, lower port matched (each runner flows 306)
    Full Fuel System good for 900hp forced induction
    Dual 255 inlines, -10 feed, -6 return, Aeromotive Regulator, Behind Bars Racecar Rails
    60lb injs
    Custom Turbo kit done by www.rtpaz.com (1500 miles on kit) Kit is Jet Hot Ceramic T4 based kit
    1 3/4 headers (V-band)
    2.5" X-over (V-band)
    3" Coldside
    MP T70 .96 a/r JetHot exh housing and polished inlet (all lettering ground off smooth)
    31x12x4 air to air intercooler good to 1300hp (3" in/out)
    Tial 44mm gate (V-band)
    Tial 50mm BOV (V-band)
    3.5" Downpipe T4 tang V-Band
    3" dynomax ultra flow mufflers
    3" tailpipe that are jethot also (entire exh was custom made with the turbo)
    Kit has ports for N20 and methanol ready to go on the coldside
    ALL T-bolts and upgraded couplers throughout
    AEM standalone, with elec boost controller, no MAF, no EGR, and no O2 sensors
    Laptop included
    AEM wideband
    TKO600 (5k miles approx)
    Pro5.0 shifter
    Spec Stg 3+ modified (1000 miles)
    Saleen 18x8/18x10s REAL Ford wheels 295/35/18 rear 245/40/18 front decent tread
    AJE front tubular setup K-member and A-arms
    MSD Dig 6
    MSD coil and plug wires...and AFM 11mm plug wires
    70mm Accufab TB
    31 spline Strange Axles (Rear end was just built 3-4 mo. ago less than 500miles)
    FMS Girdle
    04 Cobra Diff with carbon fiber clutch packs
    All new bearings in rearend and wheel bearings
    FMS 3.27 gears
    Dbl adj Uppers with UPR Solid rear end bushings
    LCA (no name) with poly bushings
    Eibach Drag springs rear with airbag
    Linelock
    QA1 14/150 coilovers in front
    D&D CC plates
    Fluidyne radiator
    Autometer Gauges...Oil/FP/Water/Boost in cabin
    Autometer pencil style shift light on colum (very sleeper)
    FMS Aluminum driveshaft upgraded u-joints
    All wiring hid in engine bay
    Long studs in the front and rear (Strange)
    Taylor battery relocation kit with Optima battery
    Car Cover
    etc etc
    Car Ran 11.2@132 on 6-8psi on DRs (2.1 60') last week on a soft tune
    $14,500
    Intercooler on the car
    Any questions please email me at Eades5point0@msn.com or PM me
    Thank you
    Chris
    whoa that thing is amazing.. bump for a nice car
    Wow - nice ride! That's a mid 10 sec car if you ever get that 60' time where it belongs...
    Good luck on the sale.
    I've known Chris for years and he is a great guy. My heart goes out to him on his recent loss. If I had the cash I'd be all over this.
    SAME HERE GREAT GUY AND CAR ,WISH I HAD THE MONEY AND ROOM FOR THAT CAR
    1,037
    He was only running 6 PSI when he ran the time posted above. If he would kick it up to 20 PSI the car would run 9's. Well if it had a full cage
    2016 Mustang GT
    Quote Originally Posted by burntire View Post
    I love the color. I trade him my pink Buick
    Stock unopened engine
    11.20 @ 119.5
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    beautiful car worth every penny and then some if i had the money i would make the trip to come get it good luck with the sale and god bless
    bump for a VERYYYYY nice car.. good luck with the sale mann
    2,103
    Very very nice car, but all that work, and a stock block? Why didnt he go with a dart or something? Just wondering if he had a reason, or I do realize that they are a good bit of money too. 2800 just for a block is crazy.
    03 Cobra=slow show car...
    13 F-150 Limited
    1,037
    He has a real block in his garage. Not sure if it goes with the car.
    2016 Mustang GT
    Knowing Chris, I think the stock block was originally used due to funds, but I think he kept it just to spite people because every thread where his car was brought up or talked about the comment was made about his stock block. I heard he had bought an A4 block for it.
    Yes, he has a virgin A4 that he wants $1200 for.
    1,037
    I will get Chris on here to answer some questions.
    2016 Mustang GT
    Thanks for all the kind words guys
    And yes all you info is correct, I have a brand new never machined A4 and a set of Bogarts that can go with the car for the right price.
    hey chris whats up ? i haven't talked to you in a long time . what brakes are on the front ? just wondering abou the bogarts if they will clear cobra brakes?
    I have new stock brakes but the Bogart wheels clear 13" brakes as it's a option you can get from them that I took advantage of incase I ever upgraded.
  1. 92 turbo lx
    By frcefed in forum Ford Vehicles
    Last Post: 05-30-2011, 01:55 PM
  2. how much to do a turbo?
    Last Post: 10-05-2008, 11:36 AM
  3. I like turbo's.........
    Last Post: 09-26-2008, 02:45 PM
  4. IHI bad,what turbo for my 2.3 turbo?
    Last Post: 03-29-2008, 11:33 PM
  5. 88 2.3 turbo
    By InfamousStang in forum Fox-SN95
    Last Post: 06-13-2007, 03:17 PM
