Results 1 to 5 of 5
Thread: C4 hardened input shaft breakage pix
    Earler this year right after I had my car inspected I took my car out on the street to test out some new drag radials. After hitting 2 gear hard my car hit the rev limiter and the car shut off. I drifted to a stop and put the car in park...the car didn't move so I knew I didn't scatter the rear end. So I coasted about a mile back to my house and pulled the tranny. After getting the tranny out I was unable to remove the torque converter so I took it to my tranny guy. The tranny guy had to drill the "button" on the converter and tap it so he could use a bolt to push the converter off. After getting the converter out he pulled the pump and the hardened input shaft wich had a brass bushing gaulded on to it. after inspection the entire tranny and finding nothing wrong he tried to get the bushing off when he noticed the the shaft was in 2 pieces!
    Its not that the hardened input shaft broke... its that it broke so cleanly it looks like it was machined..no chips,twists,cracking etc...clearly due to some kind of flaw
    Pa Tranny's told me to send back the shaft and they will send another. and the torque converter got junked too!
    Mike
    best of 9.66 at 141 MPH
    http://www.mikeymustang.com
    4,321
    wow!!! give me a call...
    WOW! I have seen they break but never that clean.
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Mike,
    it looks like there is some bluing, or signs of extreme heat. I have to wonder if the bushing was on the tight side. Repeated heating & cooling cycles would temper the steel & change the hardness.
    Mark Lowry
    Member BoneCrusher's Avatar
    Murrysville
    882
    Holy hell Mike!
    Mike
  1. Vortech input shaft problem
    By frankstang in forum Fox-SN95
    Last Post: 09-07-2012, 04:19 PM
  2. Lentech Strip Terminator input shaft/drum
    Last Post: 05-18-2011, 11:47 AM
  3. Input shaft question
    By yellowstang03 in forum General Tech
    Last Post: 09-21-2010, 06:36 PM
  4. Hours of labor to install a input shaft?
    By speedracer in forum SN95-New Edge
    Last Post: 10-28-2009, 04:27 PM
  5. Replies: 7
    Last Post: 12-08-2008, 10:11 PM
