what do you have to do to a older 351 to swap to a hydrolic roller cam
Or call Doug Herbert. They make really nice retro-fit, link bar, roller lifters that are quite a bit less expensive than most.
i got the pushrod length im just not sure about the lifters and that stuff how much for the lifter set up and total engine airflow did my heads and said most 351 have a 13cc fly cut is that true im kinda a 5.0 kinda stroker guy this is my first 331 thanks
i have pushrod length i just need to know how much for the set up for roller lifters and total engine airflow told me that most 351 have a 13cc dish piston do you guys know if thats true cause i found an older 351 and if thats true i can keep thoes pistons and run the cam i have thanks for the reply any more info is welcome
My car has 302 flat tot pistons with Vic Jr. heads and a .642 lift cam. I have no issues with piston to valve clearance and my compression is like 10.6:1
That being said, I don't think a flat top will be an issue...especially if you're not running a stroker.
