Results 1 to 11 of 11
Thread: rough idle
    plum
    487
    rough idle
    just installed a new cobra upper and lower,matching throttle body and a 1" riser and the car pulls harder but idles like crap(very choppy, shakes the car badly) and the exaust fumes are so strong I need oxygen to work on it. Checked all vac lines 3 times, and cleaned the iac and set the tps to .9 volts. Any ideas??????
    Quote Originally Posted by 89 vert View Post
    Durring the swap did you break the black box on the fire wall?
    plum
    487
    the black box to the left of the vac t? I will ckeck it now
    plum
    487
    WOW, the box is not broken but the plug on the bottom was totally disconnected!! Its too late to fire it up because my neighbors are crabby but I hope this has something to do with it. What is it?? Thanks coral
    That will for sure cause the car to not idle.
    It will run great now!
    plum
    487
    Well, after pluggin the map sensor in the car still will not idle. Checked all vac lines + pcv and all are ok 40-45 lbs gas press at the motor. pulled 1 plug to check for carbon and it was normal. Yesterday I ran the car hard with the map sensor off, I hope I did not damage anything. The raw fuel smell went away so that problem is fixed, and it runs great through the gears but just will not idle. I also disconnected the battery overnight to reset the computer. Any suggestions?? I have pulled out all my hair and my wife is ready to divorce me(might not be a bad thing)
    Shes Got Cleavage 91-350-RS's Avatar
    Plum
    27
    Well, broham. u gotta keep ur head up and dont worrie about the wife ill take care of her!
    The plugs looked fine? Hopefully it just needs cleared out.
    plum
    487
    :upyours:
    Quote Originally Posted by 91-350-RS View Post
    Just replaced all plugs, new wires will be goin on tommoro. Also checked the check engine light to see if it works and it does not. Can I check the codes, maybe I fried my o2 sensors????
    :upyours: Just replaced all plugs, new wires will be goin on tommoro. Also checked the check engine light to see if it works and it does not. Can I check the codes, maybe I fried my o2 sensors????
    I had an 88 LX that I did that with. I broke the MAP sensor though. It took a tune up and some driving to clear it out. I ran the car to work after I did that, I was on the highway so I didnt notice it untill my tank of gas was almos gone . When I pulled off, the car idled like it had a big cam.
  1. Rough Idle and Code p2197
    By map22 in forum SN95-New Edge
    Last Post: 10-20-2011, 09:26 PM
  2. 1500-2000 RPM running rough
    By venom in forum Fox-SN95
    Last Post: 06-20-2011, 10:06 AM
  3. '90 5.0 runs rough only when in gear???
    By White5.0 in forum Fox-SN95
    Last Post: 05-31-2011, 12:03 AM
  4. Rough night
    By travj31 in forum The Bar
    Last Post: 08-28-2009, 07:14 PM
  5. Crazy idle help
    Last Post: 06-10-2009, 05:55 PM
