Results 1 to 9 of 9
Thread: any ideas
    NEWB cc4x4rider's Avatar
    clarksville
    70
    any ideas
    I know its hard to fix without seeing, I just started driving my 91 gt after since last year. Its got a vortech supercharger and isnt running right. Backfiring, no power, idles pretty good, but backfires when i get on it and has no power. Motor and charger have high miles. Gonna change the plugs, but ive been thinking the MAF is going bad, any way to test it? Anyone got a chance to check it out? Im sick of projects.
    :flip:
    What's the plug gap set at? Are you sure that its not blowing out the spark?
    Mt Pleasant, PA
    4,905
    Yea, close up the plug gaps to around 30 if you haven't already. Also, if your running an FMU check to see if it has the right calibration.
    What ignition do you have in the car? Not a lean back fire is it?
    clarksville
    70
    msd 6al and vortech/msd boost timer.
    :flip:
    LowHill
    2,679
    Sounds like its leaning out, whats your fuel pres. and do you have a gauge to see if its dropping off?
    Power Adder
    236
    Bypass the MSD ignition. I've seen this problem before. The votech BTM goes bad and pulls full timing all the time making the car run like crap. I don't know how many I've had to bypass to fix a simular issue.
    Chris Kauffman
    1988 408LX drag car
    clarksville
    70
    i think my t rex is bad, fuel pressure will go 40-45 , at first which is why i didny notice it drops after that. im gonna check the wiring. So now the real question, buy a new $200 t rex or do the aeromotive sump tank and a1000 pump. any people running this??
    :flip:
    You didn't recently change plugs and/or wires did you? I guess I'll just tell you all how I noobed myself and maybe it will fix your problem...LOL
    I put in new plugs in the spring. When I was done I started the car and it idled like a champ, but if you touched the gas at all it would pop through the exhaust horribly. The car was totally undrivable. In my apparent rush to get done, I had 1 & 2 plug wires crossed. I did it in front of my wife and dad and they found that entertaining. I hope your issue is as simple as that, no matter what it is!
  1. Top ideas
    By thaley21 in forum General Tech
    Last Post: 03-16-2011, 10:51 AM
  2. any ideas?
    By 08stangftw in forum The Bar
    Last Post: 06-04-2010, 01:16 AM
  3. Need some ideas here?????
    By 1994cobra in forum Drag Racing
    Last Post: 06-05-2008, 10:15 PM
  4. Ideas on a tune??
    By v6mustang01 in forum Fox-SN95
    Last Post: 06-01-2008, 06:15 PM
  5. Any Ideas?
    By 2001GTTT in forum S197
    Last Post: 04-13-2008, 10:58 AM
