I got the "saleens" from americanmuscle and am running 275/35/18's and was wondering whats the biggest i could fit for rear tires?? i was thinkin maybe 295's possibly?
9" thinkin i shoulda ordered the 10" lol
i have seen some 315s on the 99 and up stuff...
they are the "saleen" 9" off of american muscle..
You should be able to go up to a 305 wide on most tires and a few of the mfg's run smal like Nitto which you could go with a 315 on a 9" rim.
My Rear rims have 275's I think they are either 10 or 11 " Could I run 315's?
ok thanks guys!!
it think the car could use alil more meat on the ground even if it is only an inch or 2 by movin up from the 275's
315's work fine on a 10 thru 11" wheel with the proper offset.
Mark
LeMans Blue Z06
I have the cobra 17"- 11" wheels, so the 315's would clear the quad shocks?
As Mark said, 315's will fit with the proper wheel BS and offset. However, with your 9" wheel I would not suggest running anything from a 295-up as they are too wide for a 9" wheel. They will physically go on, but they will look like crap as they will be bulging all over the place. If you get a 10" wheel the 295's fit perfectly!
I have 17X10.5" wheels (which is what I think you have too since I have never seen a 17X11 cobra style wheel). My BS is 6.75" and my Nitto 315's cleared everything without any modifications. I do know that most of the aftermarket cobra replica wheels that are 17X10.5 are closer to 6.9" BS though and therefore you may have to flip your quad shocks as mentioned by Mark.
You guys are a Great Help! Thank you!! Could I still use 40 series?
