I have a push bar, tannau cover and a set of headlight covers here from a 95 Dakota (short bed).
Push bar is a "go rhino" unit, wqas in a slight hit, the brackets are tweeked and the center bar is a little dented. All easy fixes if you need this. This is the type with the headlight guards and insets bars. It also has driving light mounted to it.
Tannau is an aluminum frame model with snaps. there is a little tear in the middle, I always just had a small piece of duct tape under it.
Also GTS?? headlight covers for the same.
All of this free if you can use it, come pick it up or else it goes in the trash.
