Results 1 to 10 of 10
Thread: Question about using n20 on the heatexchanger
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    I've seen some turbo guys hook up a halo to spray n20 through their intercooler and it got me thinking. I've got a nitrous system in this car, just not hooked into the air intake yet (not sprayed since motor rebuild) and I was wondering what effect it would have hooking it up to spray through the heat exchanger during WOT runs. Anybody done this?
    I think it would be more effective in the intake pipe...
    2.4 KB & Juice
    Export, PA
    844
    Cam I've seen a few cobra guys try this a few years back, if I remember, that barely picked up any HP. Timmy built that motor right, i'd say put it in the intake (post maf) and give her hell. I wouldn't be afraid of even doing a 150 shot, that was my plan if I kept the car. Like I suggested though, I'd move the throttle switch to the throttle body. It would definitly need professionally tuned and also the fuel system upgraded for this to be done correctly. All said and done, no reason on earth this car shouldn't throw down a 9.99
    07 Silverado
    05 R6
    IIRC Dan's car already has a WB02., right? If the current tune seems "on", why not take it to PRP to get some baseline runs? Then worry about the N20 later.
    But to answer your question...you'll see nicer gains (at the track) by running ice-water through your H/E instead of spraying hot H/E coolant with nitrous. Plus...that'll get very expensive.
    Belle Vernon
    1,294
    I have a co2 halo system on my T-type that spays the intercooler at WOT. I heard of people also using no2 but I don't think it was very beneficial.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    Melcroft
    4,178
    Quote Originally Posted by KBCobra View Post
    I will probably just spray a small shot (75ish) and be satisfied...at least for now . Will definately take your advice on moving the wot switch to the throttle body.
    Melcroft
    4,178
    I'm raelly not planning on doing any nitrous (through the motor) till next year, just thought if there was some benifit to spraying the H/E I would do it since the kits already there. I'm trying to get to prp for somebaselines, but the weather has had other ideas
    mustang aficionado SVTGT's Avatar
    176
    Turbo guys only use spray bars if its an air to air intercooler.air isnt the best way to transfer heat. same reason we dont use air cooled engines in cars anymore. the way it works is N20 is liquid in the bottle when you spray or purge it. the n20 boils and turns into a vapor when it boils it pulls the heat from the area. this cause the charged hot air in the intercooler to rapidly cool making the air denser. the reason most people with water to air intercoolers dont spray then is the fact that even if you spray at the heat exchanger your just cooling the water thats gonna go back to the intercooler which because of engine temps its usually a fairly steady temp. Water to air systems are the best way to fly, their are a very efficent way to intercool and with that systems better to just spray into the engine. 5hp by cooling the water for the intercooler or 75-150hp by spraying into the engine.
    1988 GT "SVTGT" Terminator Fox
    2003 Cobra SVTGT donor. (sad bare chassis)
    1990 LXC 4cyl. (turbo 2.3 in progress)
    2004 World Rally Blue STI (Daily Driver)
    1991 5.0 Auto Notch
    1986 notch(retired SCCA car)
    3,316
    *on
    They spray it on the intercooler and take advantage of the expanding gas cooling the air to air charge cooler. People have also used tanks of carbon dioxide for the same effect since its cheaper.
    But the consensus here is correct. Its really only effective on air to air intercoolers. You're better off hooking up the bottle for its intended purpose.
  1. wtb more n20 bottles
    By scott5 in forum Ford Parts
    Last Post: 07-04-2014, 09:44 AM
  2. 94-95 VC question
    By 94svtcobra in forum Fox-SN95
    Last Post: 09-05-2008, 04:42 PM
  3. N20 jet question
    By Cam99 in forum General Tech
    Last Post: 09-06-2007, 09:31 PM
  4. Tuning - N20
    Last Post: 07-17-2007, 09:26 AM
  5. N20 Spark Plugs
    Last Post: 05-27-2007, 12:48 PM
