Results 1 to 15 of 15
Thread: Cobra Ideas
    Senior Member Import Killer's Avatar
    Washington, Pa
    526
    Cobra Ideas
    Here's My Idea's For The Cobra Tell Me What You Think:
    I Wanna Get This Stuff Done For The FLD In Sep.
    1 Adjust The Timing
    2 Slp Loud Mouth Exhaust
    3 bbk fenderwell cold ait intake
    4 Pulley Kit
    5 Ignition Wire's
    6 Aluminum Drive Shaft
    Do You Guys Think Ill Get 50 H.P. Outa That Iam Opened To Any Sugg.
    Just spank it!!! Viper_ed's Avatar
    Fayette City, PA
    5,841
    Sounds more like 30 HP to me if you're lucky.
    1,301
    Quote Originally Posted by Viper_ed View Post
    X1...
    I like hair dryers Twin01cobra's Avatar
    Wherever I want
    1,270
    I would'nt do anything with the ignition as you will be wasteing your money, that stock ignition can handle alot of power before an upgrade is needed.
    "No man is entitled to the blessings of freedom unless he be vigilant in it's preservation"
    General Douglas McArthur
    Washington, Pa
    526
    alrite thanks for the heads up bout the ignition..i just wanna make 50 more hp with out spraying it..any ideas other then a $upercharger
    boats n hoes fork5o's Avatar
    Hopewell
    833
    you can also look into makin it better for draggin without just adding hp. id add a full exhaust, headers and mid pipe, look into some gears, and maybe lose some weight along with what you have.
    -Joe
    1995 5.0
    The Car
    Wherever I want
    1,270
    You may be able to pick up 50hp with a full exhaust with longtubes, plus all your bolt ons and then you will need a good tuner, but I still think you will fall short of your goal. You may have to get cams, headwork to reach your goal. But as stated before your best and cheapest way to go is spray a 100 shot and be done.
    Washington, Pa
    526
    alrite thanks for the help guys....i think iam gona go with the long tubes and a slp loud mouth for now
    Senior Member scott5's Avatar
    NC
    10,168
    longtubes with exhaust
    get a jlt cai
    predator tune with some gears
    Mustang Guru billyNOTnice's Avatar
    Huntingdon PA
    1,136
    import killer, i know your asking for 50 hp, however i'm not sure exactly what your desires are. if your looking for it for drag racing, you could invest some money into a set of gears and drag radials or alike. that would at least get you traction to use the power you have... as far as 50 hp goes, i'd spray it with a 75 shot.. a 75 shot wouldn't even blow up a 3 cylinder metro on youtube. :)
    Roll With The Mill Creek Mafia
    709RWHP/750RWTQ
    Washington, Pa
    526
    i wanted for mostly drag to full around on the strip and the main roads to be honest...but whoever had the car b4 me already put 4 10 gears and a short throw and a heavy duty clutch
    i dont know if i would put pulleys on it. you said it was a cobra is it a 4v? I know the pulleys do a number on the motors out here in az because of the heat and have the a/c on. there is my .02
    TJ
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    I must have missed it, but what year Cobra are we talking about?
    Washington, Pa
    526
    2001
    Melcroft
    4,178
    Since gears are already done, I'd say do a jlt cai and full exhaust. I would stay away from underdrives on a 4v. Pauls high performance makes an intake spacer for mach 1 uppers (same as cobra) that is usually good for a few hp and some midrange for around 100.oo
  1. any ideas?
    By 08stangftw in forum The Bar
    Last Post: 06-04-2010, 01:16 AM
  2. Need some ideas here?????
    By 1994cobra in forum Drag Racing
    Last Post: 06-05-2008, 10:15 PM
  3. Ideas on a tune??
    By v6mustang01 in forum Fox-SN95
    Last Post: 06-01-2008, 06:15 PM
  4. Any Ideas?
    By 2001GTTT in forum S197
    Last Post: 04-13-2008, 10:58 AM
  5. any ideas
    By cc4x4rider in forum General Tech
    Last Post: 07-29-2007, 10:13 AM
