Results 1 to 10 of 10
Thread: 87gt to sn95 front brakes
    Member 87gt's Avatar
    Feb 2011
    hopewell twp, pa
    30
    Im looking to convert my 87gt to 95 front brakes, so far i have 95 spindles,new set of timken front hubs,what else do i need for this setup? what caliper years will work? rotors?
    any caliper from 94- up to 04 will bolt on then use the same year rotor you can even go bigger like gobra brakes if you use the right cailper and rotor combo
    Feb 2011
    hopewell twp, pa
    30
    will i need to change anything else? or will that bolt on and be ok? no booster change?
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    Search for posts from 50dro. He has a bunch of information and pictures from his swap.
    2015 GTPP
    Senior Member frankstang's Avatar
    Sep 2007
    Homestead
    780
    To use the '99 + dual piston calipers you'll need to grind down the spindle just a bit. It's no big deal. If you want to use those calipers, just mount them on the spindle and you can see where the interference is. Grind them down until the caliper fits.
    I did the swap on my 86 GT. I had the narrow K frame (87-93 V-8 cars are a 1" wider). If I had the wider K frame(which your should have) all you need to do is put on the spindles. My swap was a complete 4 wheel disc conversion with the Cobra front calipers/ rotors. I actually did not change the master cylinder even though I was told that the booster and cylinder need to be changed. Once I play with it when the weather gets better I may change them over. If you need to change the booster/ master cyl, I was told for fox body cars go with a 93 Cobra booster and a 94-up master cylinder and proportional valve
    stuntman blksunshine88's Avatar
    Aug 2008
    duquesne
    544
    Take note on most fox to 94-95 booster installations, you may have to mod the strut tower to install it just a little with the dead blow hammer and you're good to go
    -greco
    92 Coupe, 10.72@133
    Chevelle Owner Tony71502's Avatar
    Jun 2008
    Bell Acres
    469
    I had to cut the studs down a bit and notch my strut tower to get it barely in. Was a pita.
    1991 Jewel Green Ford Mustang LX ~ 5.0L / 5-Speed
    2011 Torch Red Ford Ranger ~ 2.3L / 5-Speed
    1971 White Chevrolet Chevelle Malibu w/ Blue Stripes ~ 8.2L(502) / 4-Speed
    Feb 2011
    hopewell twp, pa
    30
    got one side done, looks good. i put new strange struts on also, i wish they sent the nut for the top with them. it took me two hours and half tank of gas to find the correct nut.
    Nothing clever to say.... jaa55's Avatar
    Sep 2007
    Dayton PA
    3,795
    I used a 2000 v6 booster with no strut tower beating whatsoever
    Sent from my ADR6400L using Tapatalk
    03 Torch Red Anni. Ed. Cobra
    11 Grabber Blue 5.0, 3D500 spoiler, CS valance, GT premium, interior upgrade package, Brembos, MT-82 and Whipple powered SOLD
    01 cobra: traded
    93 LX Modular 4v swap
    Sean Hyland Motorsport forged rotating assembly, Teksid block, 01 cobra heads, cams and intake SOLD
  1. 03 Cobra front brakes
    By speedracer in forum Ford Vehicles
    Last Post: 06-03-2012, 07:13 PM
  2. Bullit front brakes
    By Naste95 in forum Ford Vehicles
    Last Post: 01-31-2011, 08:15 PM
  3. Front Brakes for Fox
    By Inkdcountryboy in forum Fox-SN95
    Last Post: 09-20-2009, 09:47 PM
  4. T/W 99 cobra front brakes
    By Jper in forum Ford Vehicles
    Last Post: 02-09-2009, 11:14 PM
  5. WTB: SN95 front brackets and front cover
    By slimvdub in forum Ford Parts
    Last Post: 08-06-2008, 04:02 PM
