Results 1 to 17 of 17
Thread: Lunched another belt tonight.
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Well this is starting to piss me off. Took it out tonight just to take a quick joy ride. It was real quick. After car warmed up went wot in second and sheared off the front half of the belt again. Checked the belt constantly at prp (last time I drove it) and checked it tonight before I left and it was perfect. Took the front 4 ribs off just like last time. I 'll tell you N/A was a whole lot less of a pain in the ass. Going to shim out the idler next to the crank pulley.The belt rides close to the front edge of the idler, so maybe it's walking it out of the grove of the crank pulley??? Am going to get an inch longer belt too as this 780 is really tight. Would welcome some belt slip over shreading 30 dollar belts at this point.
    5,822
    2019 Colorado ZR2
    Melcroft
    4,178
    If it was me, I'd just give the damn car away at this point. I'll PM you my address. If you can't find anywhere else to leave it, I guess you could put it in my driveway for a few days.
    Cam, I know this sounds really stupid, but sometimes it's the easiest stuff. Is everything tightened down? Maybe the s/c worked itself a little loose since it was off the car and the snout is moving around a little? And, try a laser pointer on the edges of those pulleys.
    Just a few easy thoughts... pardon my s/c stupidity, but the simple shit normally bites my ass.
    Good Luck !!!
    What am I looking for with a laser pointer? I am going to check to make sure all is tight once the bitch cools down some tonight. It only takes about six hours with the hood up to cool the engine bay off somewhat .
    5,822
    2019 Colorado ZR2
    boats n hoes fork5o's Avatar
    Hopewell
    833
    when i was figuring out what size belt i need it, started shreading on the outside of the belt that was too tight
    -Joe
    1995 5.0
    The Car
    Senior Member 32valve's Avatar
    earth
    154
    belt
    You have something out of alignment, or something walking in and out to shred a belt that quick. Take the time to take it apart and check all the pulleys', It should be obvious. Good luck.
    66 Fairlane GTA 390
    2011 f150
    08 SHELBY GT500 (sold)
    04 COBRA (sold)
    Melcroft
    4,178
    Quote Originally Posted by 32valve View Post
    Checked every pulley. All spin freely, don't have any damage or burrs on them , and don't have endplay. I checked to make sure the crank pulley wasn't loosening up, and all bolts are tight. The only thing I found that was different is that on all the aftermarket pulleys the belt pattern shows that it rides toward the inside of the pulley and the ford idler next to the crank looks like it used to ride towards the inside, but now is riding towards the outside. Took the pulley off to get a close look. The bearing is fine and the pulley spins freely. Used a washer behind it to space it out farther so that the belt will ride closer to the inside like all the rest. I'm going to get a little longer belt when i put it back together. I don't know anything else to check. I've spent lots of time now under the hood with the car running and nothing is wobbling or showing any signs of bieng abnormal.
    Hi I'm Stupid 393rag's Avatar
    FayetteNam
    889
    I think what you really want to do is trade me for a nice shiny Camaro. That will fix it!!
    Melcroft
    4,178
    Quote Originally Posted by 393rag View Post
    LOL. Wouldn't mind the rims from said shiny Camaro
    3,356
    Cam I think I know the fix.
    There is a lower on that car right?
    I am betting if there is, that the idler pulley at the bottom is in the lower hole. If you put it in the upper hole the belt will walk when you wick the throttle open quickly leading to the belt tearing.
    Give me a call at 412-262-9020 x3022 before noon today if you can and I will explain this further. If you can't call by then pm me your number and I will call you later.
    Mark
    LeMans Blue Z06
    FayetteNam
    889
    What would you be willing to pay for said wheels and tires?
    3,316
    he wants to trade it for a turbo neon!
    4,321
    cam,
    if you haven't got everything worked out yet, i would be happy to take a look at it for you. i know your kinda far from the garage but i have seen this many times. there are several things that could be the problem...
    mike
    3,356
    Cam did you check the items I told you about? Let me know bud!
    Mark
    LeMans Blue Z06
    Melcroft
    4,178
    I did Mark. I don't have an adjustable lower idler. It looks like the tensioner is pulling it out towards the front of the motor and walking the belt off. I finally caught it in the middle of destroying the belt to see what it was doing. Never made it to the flds, ended up finding the belt pulled one rib off when I got to my uncles in greensburg and just left it there and took his Magnum.
    Melcroft
    4,178
    cam,
    mike
    Thanks Mike, I think I finally got it figured out. Thanks to everyone for your help
    Melcroft
    4,178
    OK two thousand four hundred belts later I think it's solved. The crank pulley was about 1/8 inch back towards the motor compared to the rest of the pulleys and the belt was walking forward one rib . Fabbed some spacers behind the lower and put it all back together with another new belt. Took it out tonight and ripped around on it. Belt is still aligned in pulleys and unharmed. Not claiming victory yet, but this is the longest a belt has lived so far anyway.
  1. belt size???
    By 94gt5.0 in forum General Tech
    Last Post: 11-12-2009, 04:52 PM
  2. What size belt do I need?
    By Milewsky80 in forum Fox-SN95
    Last Post: 11-05-2008, 07:53 AM
  3. belt help
    By silvernotch in forum General Tech
    Last Post: 05-19-2008, 10:33 PM
  4. Had to change my serpentine belt tonight...
    By Cam99 in forum SN95-New Edge
    Last Post: 08-16-2007, 12:36 AM
  5. Short Belt
    Last Post: 07-16-2007, 12:36 PM
