Results 1 to 10 of 10
Thread: Please Help!
    Ligonier, PA
    6,365
    Please Help!
    Hey everyone....i have a car problem...(go figure)... whenever i stop the car and shift into reverse, sometimes the rpms dip low and it feels like its on the verge of stalling....same thing happens at times when i brake hard....any suggestions or ideas of what it could be and how much it would be to fix will really help. thank you. clark by the way it is an automatic....problem started not too long ago.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    5,822
    2019 Colorado ZR2
    Ligonier, PA
    6,365
    the rpms do return to normal...car has around 65k on it...just worries me because it didnt do it before...it does it more often when i go into reverse....it dips really low like 200rpm...then back to normal.
    1991 BMW 325iX
    1978 Ford F150
    Going fast with class Slow01GT's Avatar
    Mars, PA
    1,696
    It could just be a ford thing like Troll said, or your idle air control valve could be going on you. Mine did the same thing a few years ago and then just kept stalling out after a while.
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Chandler, AZ
    1,532
    Quote Originally Posted by 2001GTTT View Post
    when's the last time you changed your fuel filter?
    BUTLER,PA
    161
    Mine did the same thing. eventually it will stall all the time. change your IAC valve...fixed mine
    '04 Black Cobra Coupe
    2.2 Kenne Bell, FIPK, Accufab TB and Plenum, Bassani catted X, Borla catback, Head Cooling Mod, LFP HE, SCT custom tune by Terry@Street Lethal Performance
    Complete IRS bushing kit, FLSFC's, BF IRS Brace and Brackets, MM adj tie rod kit, MM aluminum steering rack bushings, Fiore quadrant and ADJ, MGW shifter
    Ligonier, PA
    6,365
    thank you guys....you are car geniuses any guess on how much this wil cost?
    1991 BMW 325iX
    1978 Ford F150
