Results 1 to 3 of 3
Thread: EFI Accel Gen 7 DFI for Mustang/Ford TFI $1300
    never stock biminiLX's Avatar
    Beaver
    2,406
    Gen 7 DFI from Accell for Mustang/Ford TFI. Updated with all new features by Accel in Fall '05 (have receipts). I then tore the car apart for a cage, rear, turbo, etc. only firing it once with all the upgrades.
    Comes complete with all harnesses, USB Pro Key, base Power key, 2 MAP sensors (1 new), new air temp sensor. Only thing required to fire a Mustang is an IAC motor (I modified mine to use with my intake/hood and will need to keep it). You can use any GM factory application IAC, but might want to call Accel for their best recommendation.
    The computer is not a wide-band 02--it can be upgraded to this or read from an aftermarket wide-band sensor if you set that up.
    It is 1-bar MAP sensor kit and can run both sequential or batch fire. Great if you are planning NA with track nitrous like I was as the Gen7 can control 3 stages of Nitrous by itself. Also Accel is well known for good customer service and being able to do many street-friendly features.
    Anyway, its is fully updated, has several base tunes for a stroked 351 (save you a lot of time with any SBF but I had a street 427), has the expensive USB Pro-tuner key for your computer ($250 alone) plus a standard key, 2 MAP sensors and several other new sensors.
    This is everything you will need and it is complete. I still have the instructional CD.
    $1300
    I have just over $2000 in this.
    I'm only selling because I needed a wide-band set-up for the turbo and my tuner is more comfortable with FAST XFI.
    Thanks, J
    drjotting@yahoo.com
    Beaver
    2,406
    Box, CD, USB Pro Key (allows ALL functions to be used, not in base kit), standard key, 2 computer cables:
    Box clean terminals:
    02 harness, MAP sensors, TFI harness, injector harness with numbered injectors:
    Main harness, with labels on some connections:
    Bad pic but dated receipt for $280 Pro-key and upgrades:
    Also, the wiring harness also includes wiring and a 40amp fuse for a fan control. I ran my twin Spals off the DFI, a nice feature and the wiring is set-up for whoever buys this.
    I will email some extra tunes I have that Accel modified directly. The tune in the box will (should) make a SBF fire and idle. Mine was great WOT and not fully completed for street manners, but this should help someone and save time.
    -J
    Beaver
    2,406
    $1200
  1. Gen VII Dfi with brand new WB box plus Extras $850
    By NOVICOUPE in forum Ford Vehicles
    Last Post: 01-13-2013, 01:02 PM
  2. 3000gt parts first gen, 2nd gen
    By dirtychuckie123 in forum Ford Vehicles
    Last Post: 01-10-2013, 01:24 AM
  3. Gen VII DFI w/ brand new wideband box and extras for SBF
    Last Post: 11-26-2012, 10:30 PM
  4. Replies: 9
    Last Post: 11-06-2011, 01:06 PM
  5. Nitrous Express Kit, (All Ford EFI)
    By flappy188 in forum Ford Vehicles
    Last Post: 03-05-2009, 03:51 PM
