Results 1 to 20 of 24
Thread: Car won't start
    Senior Member blkp42e's Avatar
    North Hills
    1,229
    Car won't start
    Installed new lifters, put the lower intake back on, adjusted the rockers, put the upper back on.
    now im trying to time the car. the car gets spark and fuel, but wont fire.
    i have aligned tdc on the balancer to match the 1 on the distributor cap. im totally lot. ive tried 90 out, 180 out, 270 out, nothing........
    help!!! flashlights in a week!
    how did you adjust the lifters??
    North Hills
    1,229
    http://www.fordracingparts.com/downl...M-6564-All.pdf
    edit: what do you mean adjust the lifters? i adjusted the rockers. the lifters just drop right in correct?
    Quote Originally Posted by blkp42e View Post
    Okay, but are you sure that #1 was on the compression stroke at TDC? Pull #1 plug, put your finger over the plug hole to make sure its on compression stroke, then align with TDC and drop the dizzy in pointing at #1.
    BTDT..
    Bob Myers
    North Hills
    1,229
    turn it over by hand or with the key with finger over the spark plug hole?
    is this the same as the 180 out?
    im gonna try that in the morning. getting kinda late to try to start it tonight
    I dont know, on a 4 cylinder I can turn it with a ratchet, you might need to have someone bump the key to do it with a V8?? Just bump it until it pushes your finger out then rotate the balancer a little by hand to get it TDC. Yeah it would be 180 out if its not on TDC compression.
    Bob Myers
    i meant rockers... you know what i meant... i have just seen alot of people adjust the rockers with the lifters not pumped up... and that instruction sheet is a little vauge. to adjust the intake valve you must rotate the engine until the exhaust valve of the same cyl starts to move, then go to 0 lash of the intake valve and give it 1/2-3/4 turn, to adjust the exhaust valve, rotate the engine until the intake vavle goes all the way open and 3/4 back shut, then go to 0 lash on the exhaust valve and give it 1/2-3/4 turn, and always rotate the engine in its normal rotation (clockwise). this is the ONLY correct way to adjust your valves...
    North Hills
    1,229
    yeah thats what we did tim. would the rockers being possibly misdone cause it to not turn over at all?
    usually with an improper rocker adjustment the engine will still fire, but will pop through the intake and exhaust, thats kinda wierd that its not firing at all???, give it a tiny shot of either just to see. are the plugs getting wet with fuel??
    Do you have a good seal on the intakes? A nasty vacuum leak will cause this also. Happened to me before.
    North Hills
    1,229
    Quote Originally Posted by Rodeheaver's View Post
    yep
    Quote Originally Posted by wick View Post
    i guess that's my next step. ill try pulling the upper and lower back off today
    Senior Member coralcoupe1993's Avatar
    Robinson
    3,842
    The 1st time I did HCI back in the day, I did the rockers with no pump in the lifters. It is easy to do that and easy to be off 180 with the dist. Even with that it sould at least burp. How do you know you are getting spark?
    87 GT
    93 Notch
    60 Country Sedan
    Fairlanes/Galaxies 59-68
    67 Contiental 4 door
    06 Powerstroke
    North Hills
    1,229
    when i had the coil wire off and tried cranking it i had spark going around the coil. maybe the coil is bad????
    im goin try arch a spark.
    but the timing light worked hooked to the plug wire so id have to have spark, correct?
    Robinson
    3,842
    Sounds like you may have spark. Arch it at the plug.
    87 GT
    93 Notch
    60 Country Sedan
    06 Powerstroke
    North Hills
    1,229
    quik told me to loosen the rockers and run it to temp and then tighten them down.
    said he and shaggy both had the same problem with theirs
    Robinson
    3,842
    Great aproach! Do that it will pump the lifters and hopefully they are loose enough for your valves to close. ;)
    87 GT
    93 Notch
    60 Country Sedan
    06 Powerstroke
    North Hills
    1,229
    i loosened the locks on the lifters, just dont know how loose i should loosen the rocker bolts. i guess ill just try a few settings. the north hills needs more knowledgeable stangers. lol. and come to think im gonna need a case
    North Hills
    1,229
    took the load off them till i can spin the pushrods. and tried starting. kinda putts and blobs. battery is dying though so im charging it. i think its gonna fire up
    Robinson
    3,842
    Nice!
    87 GT
    93 Notch
    60 Country Sedan
    06 Powerstroke
    North Hills
    1,229
    with alot of help from quik we got it started but still sounded like shit. found some metal in the oil filter. retightened the rockers some more and tomorrow once i change the oil im gonna try to fire it again
  1. Car won't run.....
    By Viper_ed in forum Wolfpack Speed
    Last Post: 08-20-2010, 01:38 PM
  2. 99 gt won't start! any ideas?
    By boost_92 in forum SN95-New Edge
    Last Post: 06-10-2009, 12:15 AM
  3. 95 Gt Won't Start
    By 955.0 in forum Fox-SN95
    Last Post: 09-27-2007, 12:16 PM
  4. 95 won't start when cold
    Last Post: 08-14-2007, 10:22 PM
  5. Replies: 16
    Last Post: 09-24-2006, 04:53 PM
