2000 MUSTANG GT
VORTECH SUPERCHARGER MODEL V1 515/453 RWHP/TQ @12PSI
MMR MOD 900 FORGED SHORTBLOCK RATED 900 HP AND 8000 RPM
HOUSTON PERFORMANCE S292 BLOWER CAMS
MMR HIGH FLOW OIL PUMP WITH CYRO GEARS
DO IT YOURSELF FRONT MOUNT INTERCOOLER
KAUFFMAN MOTORSPORT TUNED SCT CHIP
PRO. PRODUCTS 75MM THROTTLE BODY
PRO. PRODUCTS POWERFLOW PLENUM
03 COBRA DUAL FUEL PUMPS AND TANK
42LB FORD RACING FUEL INJECTORS
BREMBO DRILLED/SLOTTED ROTORS
MAC CATBACK W/3.5" CHROME TIPS
DRIVERS SIDE HEAD COOLING MOD
XTD STAGE 3 6 PUCK CLUTCH
KENNE BELLE BOOST A PUMP
MAC LONG TUBES/H-PIPE
COBRA BRAKE UPGRADE
HAWK HPS BRAKE PADS
NGK B7E'S SPARKPLUGS
180* THERMOSTAT
AFM 4" BOOSTPIPE
SCT BA 90MM MAF
EGR DELETE
SHOW:
CERVINIS STALKER HOOD
03 COBRA BUMPER
17X10.5/17X9" BLACK DEEP DISH COBRA R RIMS WITH POLISHED LIPS
LOTS OF LITTLE VISUAL MODS
FUTURE MODS INCLUDE:
CAM SPRINGS
60LB FUEL INJECTORS
MMR STAGE 2 HEADS
MMR 7QT OIL PAN
ENGINE SPECS
MMR MOD 900 SHORTBLOCK RATED TO 900 HP AND 8000 RPM.
HERE ARE THE FINAL BUILD SPECS
PISTON TO WALL CLEARANCE .0035
TOP RING GAP .025
SECOND RING GAP .022
PISTON WEIGHT 461
ROD WEIGHT 605
ROTARY 442
ARP MAIN STUDS AND ROD BOLTS
MANLEY 18CC NOTCHED PISTONS/H BEAM RODS SHOT PEENED & MAGNAFLUXED
FORGED COBRA CRANK/W MIRCO POLISHED JOURNALS
MMR HIGH OIL PUMP WITH CRYO. TREATED OIL PUMP GEARS
STOCK HEADS, INTAKE,
DIY FRONT MOUNT INTERCOOLER SET UP
DYNO SHEET, TIME SLIP AND VID OF A BAD 1/4 PASS
CLICK TO SEE VID
I'M IN THE RIGHT LANE
CLICK TO SEE VID
