i just put a ported e6 manifold and front mount intercooler along with a ranger rad i have yet to drive the car but it should be better than the leaking e3 that was on there![]()
Stick with the basics! A ranger roller frees up a little Hp & porting the intake is worth a few Hp.
With a Big Valve head and a little home porting and 25+ lb your in the 350 Hp zone..![]()
289 slabside cobra![]()
6S1941![]()
Troy, if you bring the car over sometime today I'll take some pics for yuo since you don't have a camera.
well guys i drove the car yesterday and it pulls real good the temps stay lower in traffic too i ran a 5.0 and stayed right beside him![]()
Here's a little incentive for ya.. And the durability of these little engines..
This is from TurboFord..![]()
http://www.turboford.net/ubb/ultimat...=042743#000000
"Did some rough tuning today on the dyno, ran out of time and ice. Also put a FAT crack in my fancy header...yay.
Results were 511hp at the wheels. 28-30# boost. Torque was similar.
Still stock 95,000 mile shortblock, cast iron D port head."
6S1941![]()
thanks for the link i go on there all the time thats where i got the idea for my volvo front mount and ranger rad . so far they are both working great i need more booost![]()
What's the boost set at now? With a FMIC 25lb. with good gas should get you down the road...
6S1941![]()
its around 17 or so the buzzer goes off every so often i guess i need a new boost gauge too as i peg the stock onei'll try 25 lbs and see what happens
actually a fairmont mmmm wonder who??? i pulled him first from a roll then out of the hole he pulled me til about 3rd gear![]()
Yank the wire off the overboost solenoid and be done with that noise. Get a gauge and crank the boost, life begins at 20 psi with these things, 25 psi is sweet with a stock T-3, but you better be cranking the fuel into it too :D
You are pretty safe to about 21 psi without getting to radiacal with a big front mount like mine. If you have the dual pump setup you should be okay at that level, if its an 86 with the single in tank, get a 255 HP pump. Remember you are referencing an extra PSI of fuel for each pound of boost, and you NEED to keep up on both flow and pressure at these levels ;)
the car has a new intank pump i just am hoping its a 255 it also has an adj. reg too ,my next things i need i guess are boost and fuel pressure gauges .i had the vovlo intercooler checked to 20 psi so i'll try that , i have a bigger front mount to try but it wil require removing the front bumper to put it onthen comes the holset hy35
I'm finally back home from China now, got a set of 55's for mine and a TwEECer to adjust the PE. I am hoping to get it all in this week, and be at all three days this weekend at PRP. Going ot yank the front sway bar, and throw the other springs in, and see what she will do.
