Lets talk about fuel pressure. What fuel pressure would you put to a 5.0 with HCI? Assume all Trick Flow stuff with 24# injectors
How about a 5.0 with only an intake?
How about a 5.0 with a wet Nitrous 125 shot?
i run 32-35 on my car(vac line on)with 24# injectors and trick flow top end
stick with 40 vacuum off when runnig any wet kit.That is what they want to keep the mixture correct
As for N/A check your plugs.Alot of cars will be different
88 GT...and some boost
40 vac line off = 32-25 vac line on
