Results 1 to 6 of 6
Thread: Changing Trac-Lok
    Senior Member LXguy88's Avatar
    Ohio/Blairsville, pa
    127
    Changing Trac-Lok
    I'm rebuilding my trac-lok and i want to know if anyone has changed up the order of the steels and frictions. It came out with .070 shim F-S-S-F-S-S-F-S-S-F. I put it back in as .030 shim F-S-F-S-F-S-F. any thoughs?
    EVOL302GT
    1990 LX -SOLD- now SVTGT's car
    1987 GT >cobra inspired
    1984 Chevy Silverado shortbed- 305 monster
    Quote Originally Posted by LXguy88 View Post
    the first order is correct, 2 steels go together between each clutch, but whos to say more clutches will not help for positive traction... try it and see...
    Mt Pleasant, PA
    4,905
    I like to pull one steel and add one of the used frictions instead, seems to work pretty well. I do the second order you have.
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    I used this method as well and it works fine for me, so far no one-wheel peel.
    Mark Lowry
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I hear a lot of people saying they like the F-S-F-S-F-S-F setup and 'it better' because there is more clutch material, but I have never seen any factcual information or performance numbers on that setup. What about using the carbon fiber clutchs insteed of the regular clutchs. Anyone try that? Was it any better?
    Quote Originally Posted by DRRummel View Post
    I have a set of the CF Clutches here, but will not try them until the next rebuild, and that might be next year the way it looks. I have always done the stock type stack, just shim the heck out of them. One other point, I have problably doubled the life of my TL clutches when I put a line lock on the car. I geuss those rear brakes dragging really put a hurting on them.
  1. Coker Pro trac tires
    By spectre in forum Ford Vehicles
    Last Post: 06-16-2011, 10:39 AM
  2. Trac-lok help
    By 05mineralgt in forum General Tech
    Last Post: 11-13-2009, 11:34 AM
  3. 4.10 gear install & Trac-Lok rebuild
    By wicked400ex in forum Wolfpack Speed
    Last Post: 04-24-2009, 03:16 PM
  4. Trac-loc rebuild questions.
    By Gearbanger99 in forum General Tech
    Last Post: 05-01-2008, 11:26 AM
  5. WTB 8.8 31 spline trac lock
    By Rio94gt in forum Ford Parts
    Last Post: 06-29-2007, 03:41 PM
