Results 1 to 7 of 7
Thread: 95 Gt Won't Start
    Lovin my 302
    Chicora, Pa
    116
    95 Gt Won't Start
    Well I started a thread about this a while ago. My 95 has been giving me problems with this for a while and I'm stuck! When I go out in the morning most of the time the car won't start, when I turn the key on I hear the fuel pump cycle but kinka quiet I could try starting the car all day and its dead to the world, what I had to do to get it running is just wait with the key on and eventually I would hear the fuel pump cycle again and then it would start. Everyone I talked to said change the fuel pump thats how they go slow and eventually it won't work at all, it does not have enough pressure to do the job. So I changed the fuel pump and I still have the same Problem. Any one have any ideas and help at all would be Great!! Thank you
    i b where im at
    674
    car
    did u check regulator . also could be the cap and rotor . i had that prob before on a 93 i had. tried cleanin the rotor and cap but did not work had to replace them .
    shaler,pa
    1,010
    Sounds too me like would try a f/p relay cheap try and thinking might be the fix.
    89 Mustang (stock) DD
    82 Trans Am (not stock)
    98 Audi A4 (not so hurting)
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    X2..
    Lovin my 302
    Chicora, Pa
    116
    Could be the fuel pump relay but its in the CCRM which is $120.00 but I ordered it today. So well see
    Lovin my 302
    Chicora, Pa
    116
    Quote Originally Posted by 955.0 View Post
    Well that did not fix it.
    try this, wait till it will not start, unhook the intake tube and give it a little squirt of either then try and start it, if it starts you know its a fuel problem but if it still doesnt start give the either one more try with maybe a larger squirt, if still nothing then you should check the spark..
  1. 99 gt won't start! any ideas?
    By boost_92 in forum SN95-New Edge
    Last Post: 06-10-2009, 12:15 AM
  2. my boss just won
    By madmaxin22 in forum The Bar
    Last Post: 10-01-2007, 04:51 PM
  3. Car won't start
    By blkp42e in forum Fox-SN95
    Last Post: 09-09-2007, 02:59 PM
  4. 95 won't start when cold
    By 955.0 in forum Fox-SN95
    Last Post: 08-14-2007, 10:22 PM
  5. Replies: 16
    Last Post: 09-24-2006, 04:53 PM
