Results 1 to 13 of 13
Thread: Need some stud/axle help
    Well here is the problem.. Three of the holes in my axles are stripped out. When i switched my tires they were really loose and i thought maybe it was just the stud so i got three new studs put them in and still the same thing. These wiggle so bad that it loosens my lug nuts to the point every time before i drive i have to tighten them up. So what should i do? Should i tack weld the three loose ones? Put some good ole JB weld? or what should i do?
    Banned George C's Avatar
    1,490
    pound them out, install new ones
    I did that.. the inside of the hole on the axle is stripped smooth
    I don't think it is supposed to be threaded in the 1st place. The studs should press in.
    I like hair dryers Twin01cobra's Avatar
    Wherever I want
    1,270
    That's from doing all them burnouts
    General Douglas McArthur
    Mt Pleasant, PA
    4,905
    I wouldn't put my life on the line, get a new or used replacement axle. All gt v6 and cobras from 94 - 98 are the same.
    1,490
    get new one that has a larger NULL but if doing this make sure you do all your studs like this
    they are moser 31 spline axles
    it feels like and looks like there are notches in the axle
    Did you use the wrong diameter stud?
    just been thru this...
    Moser axles studs are nothing more than grade 8 1/2 inch bolts that thread in from behind...
    The only thing you can do at this point is send the axles back and have them upgraded to 5/8" studs...
    trust me you don't want to JB weld them in... it isn't fun spinning down the 1/4 mile!!!
    Mike
    best of 9.66 at 141 MPH
    http://www.mikeymustang.com
    Are the Mosers actually threaded for screw in studs or just smooth holes for press in studs? I use Moser 31 spline axles with Moroso 3" studs. Need .625" knurl for the press in studs.
    As for the JBweld....umm just back away slowly and put the lil tubes down.
    but they came on the car when i bought it.. would this be a problem sending them back?
  1. I need an adjustable pivot stud asap!!
    By 97LaserRed in forum Ford Parts
    Last Post: 09-16-2011, 07:59 PM
  2. Long Wheel Stud Install
    By NateSVT in forum General Tech
    Last Post: 07-12-2010, 02:31 PM
  3. stud help needed
    By 05mineralgt in forum General Tech
    Last Post: 12-30-2009, 08:47 PM
  4. HELP!!! so I stripped a stud in the manifold!
    By Chargin2004GT in forum General Tech
    Last Post: 07-05-2008, 11:35 AM
  5. 3" over axle tailpipes & under axle anti-roll
    Last Post: 05-03-2007, 11:11 AM
