Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
Thread: how hard to swap a 351
  1. #21
    Farmington WV
    4,672
    Quote Originally Posted by i1arunit View Post
    The GT-40 are WAYYYYYYYYY overpriced no matter where you look. Personally I would go buy the Trick Flow R Intake for less money brand new. The Trick Flow R lower out of the box will outflow even a fully ported & welded GT-40 lower.
    yes but id need a 351 lower. which is why i thought lightnings. if i could find one id be 50% ready to build the motor.
  2. #22
    Quote Originally Posted by jared View Post
    Trick Flow does offer their intakes with 351 Lowers. Or you could go with a EFI Truck 351 Lower which is basically the same as a Holley Systemax.
  3. #23
    Farmington WV
    4,672
    forgive my ignorance....im ok with the trick flow.... but EFI....your meaning a stock truck 351 lower correct.
  4. #24
  5. #25
    Farmington WV
    4,672
    thanks man....im sill a bit of an engine noob, especially with pushrod V8.
  6. #26
    Hi I'm Stupid 393rag's Avatar
    FayetteNam
    889
    I have an aluminum FI 351w lower intake from a truck for sale, and an oil pan for a fox swap. You can have both for $100
  7. #27
    Farmington WV
    4,672
    Quote Originally Posted by 393rag View Post
    i wouldnt need the pan...my swap would be into a 94-95
  8. #28
    FayetteNam
    889
    I'm 99% sure the pan will still work on a 94-95. The k member is the same as the fox cars. I have some other misc. 351w stuff as well. If you need anything let me know, I may have it.
  9. #29
    Farmington WV
    4,672
    cool...your from uniontown pa? not far from me...ill be in touch.
  10. #30
    FayetteNam
    889
    No problem man. Anything I can do to help.
  11. #31
    Senior Member Shaggy's Avatar
    space
    278
    Do you like phill collins, u1arunit ?
  12. #32
    Member DING's Avatar
    New Bern, NC
    324
    I have a set of 351 HP drop solid motor mounts and a set of 351 swap header that will work for you car. PM me if you are interested. I have done a few 351 swaps in fox bodies, sn95's and rangers. Good luck
    Hank
  13. #33
    http://www.mustang50magazine.com/techarticles/18818/
    I used this as a guide. I also needed after market fuel rails (the stock ones weren't wide enough, the 351 intake is wider) a fuel pressure regulator (the rail mount won't work) and many fuel rail fitting to hook into the stock fuel lines. I bought the 351 headers but I could not get the old 302 h-pipe to seal. I had to buy a new 302 h-pipe. It says the a 86-93 will need a accessory drive kit but the 94/95 did not. I did need the damper spacer. If you need any other info or part # let me know.
    Tom
  14. #34
    Farmington WV
    4,672
    great thread guys. got it bookmarked for later when i find the right donor 5.0 car.
  15. #35
    A windsor is pretty much the same as a 5.0 except for 1 inch of deck height, and no you dont have to mill or shave anything, all you need is a pan and headers, i have a new moroso pan i accidentally ordered for a customer i will give you a deal on...
    PM me if you have one for sale.
  16. #36
    2,483
    No, 5.0 lower will not work because the increased deck height requires the requisite intake to have more width.
    Joe pulling out the thesaurus. My head almost hurts!
  1. Hooker 2" 351 mustang swap headers
    Last Post: 05-12-2014, 12:50 AM
  2. just wondering how hard...
    By Black87GT in forum The Bar
    Last Post: 02-07-2010, 10:36 PM
  3. how hard?
    By crusher101 in forum General Tech
    Last Post: 06-10-2009, 11:38 PM
  4. How hard would this be to fix?
    By 2001GTTT in forum S197
    Last Post: 01-30-2008, 08:19 AM
  5. 351 swap
    By bluenotch35 in forum Fox-SN95
    Last Post: 07-19-2007, 08:41 AM
