TFS Stage 3 Heads
Holley Sytemax Intake
TFS 1.6 Roller Rockers
Anderson N51-HR Cam FMS
30lb injectors Accufab
70MM Race TB Anderson
4" NA Power Pipe
PMAS 95mm Mass Air cal for 30lb
ASP Street Underdrive Pullies
TFS Stage 3 Heads
4" NA Power Pipe
those are nice numbers til you look at yours![]()
impressed!!!![]()
1986 GT:331, Edelbrock Vic Jr heads, Jay Allen custom cam, TFS R intake, 30# injectors, 75mm t-body, 80mm PRO-M, AFM Powerpipe, BBK 1 3/4 long tubes, BBK X pipe, 4.10s, 5 lug conversion, 99GT rims/Nitto DRs, PBR brakes, Lakewood 50/50s, Moroso rear drag springs, Sub frames, 2.5" cowl, Saleen spoiler
Power of a low 12 second car, Traction of a high 14 second car!
The heads on this combo were ported by JDC in Illinois. They are the stage III T.W.
"Stage III ($1050.00) The intake and exhaust ports are ported and shaped for maximum efficiency, which includes the bowl area under the valves, valve guides being narrowed and shaped and the intake track satin polished and exhaust highly polished. Combustion chambers are shaped, polished and blended to the valve seats, intake ports are matched to a Felpro 1262 intake gasket and the exhaust port to a Felpro 1415 gasket with valve seats and valves receiving a performance multi-angle valve job."
It seems as if the increased port volume *could* be a contributing factor in the avg. torque production being a little low. It would be interesting to see how the dyno numbers translate to e.t. with this particular combo.
They nailed the A/F ratio at 13:1 throughout the greater part of the pull. A PMS was employed as a tuning tool on this example.
