Results 1 to 8 of 8
Thread: valve and Piston-not a good relationship
    Senior Member LXguy88's Avatar
    Ohio/Blairsville, pa
    127
    I'm putting the 347 together still, now i;m kinda in a pickle. I went to summit today to pick up parts and talked to the mustang chick i always deal with (holly, she knows her stangs) My set-up is DSS 347 with -3cc flat top, gt-40x heads, trick flow stage 2 cam, and 1.6 FRPP roller rockers. I'm gonna check piston to valve clearance but i was wanting to know if anyone is running this cam and if they had any clearance problems.
    EVOL302GT
    1990 LX -SOLD- now SVTGT's car
    1987 GT >cobra inspired
    1984 Chevy Silverado shortbed- 305 monster
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    that cam will clear all day with those heads, pistons and cam u could clear a stage 3 if u wanted to however e
    its always good to check p to v just to be safe though
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    I'd agree it Should clear. Take the time & do a clay test. Do you have a solid converted HR lifter?
    Mark Lowry
    127
    hyd. roller
    EVOL302GT
    Caledonia, Ontario
    620
    Most aftermarket pistons have larger valve notches to allow larger valves & higher lift/duration cams. Take your time & do the test.
    Mark Lowry
    the dss short block should have piston notches for 2.05 valves, so yes yours should deff clear, i have used there stuff with 700lift cams and vr junior heads(2.05 valve) and have had enough clearance with .0045 head gasket..
    Daily driver?
    127
    yes. more or less a nice day car but thats what it was bought as. I checked it today and came up with about .200 clearance. I had to buy guide plates but now i have to send the heads out to have the pedestals machined the thickness of the plate.
    EVOL302GT
  1. Good way to remove rust on the valve springs?
    By TBone7281 in forum General Tech
    Last Post: 07-03-2014, 08:38 PM
  2. piston to valve clearance
    By blksunshine88 in forum Fox-SN95
    Last Post: 04-20-2009, 12:34 AM
  3. Anyone know of a GOOD machine shop to do a valve job?
    By Killercanary in forum General Tech
    Last Post: 03-30-2007, 02:12 PM
  4. Replies: 5
    Last Post: 03-13-2007, 11:16 AM
  5. fundamentals of piston to valve clearance
    By George C in forum General Tech
    Last Post: 11-11-2006, 01:28 PM
